merlin
posted on 19/8/02 at 08:44 PM |
Smokin!
Have an 1800 pinto, smokes a little! Had a misfire which turned out to be no.3 so changed plug. Missfire went for about 20 mins and then came back.
When removing ALL plugs a wiff of smoke came from no.3 hole. Does this mean that the valve guide seal is knackered? If so, can it be sorted without
removing head??
Answers on a postcard!!!
shit happens! (but why always to me!!)
JohnFol
posted on 20/8/02 at 07:10 AM |
I heard of a trick to do this without removing the head, but it related to a vx engine, but it might work.
Take plug out and rotate crank until No. 3 piston is on the up stroke. pass through spark plug hole loads of string. Continue on the up stroke so the
string is compressed againset the bottom of the valve. This should hold it in place whilst you do the seal . .. .
bob
posted on 20/8/02 at 09:35 AM |
there is a tool that holds up the valve while compessing the spring,only seen it used on CVH though.
I'm sure build guru rodkidcon will know
ChrisW
posted on 20/8/02 at 12:45 PM |
I've heard of a thing (might have been one of you lot that told me about it) like a bolt with the same thread as a spark plug with a hole right
through the middle connected to a compressor. Basically you screw it in, pressurise the cylinder and the air holds the valves in place while you
change the seals. Not sure if it works but sounded like a good idea to me!
Chris
My gaff my rules
theconrodkid
posted on 20/8/02 at 10:23 PM |
ill have a look on sat pm if your in,gis a bell or a mail.no sugar ![](/images//smilies/bigsmile.gif)
johnston
posted on 20/8/02 at 10:35 PM |
the compressed air in the cyliner does work ive done it BUT!!!!!!!!!!
u need to make sure its exactly tdc or else the piston can drop under pressure and then so does the valve
also u need to be very careful with the valve collets that u dont drop em down the oil ways )seen it done when i was in tech one of the other
apprentices own cars at 4 oclock when we finished at 5)
the cvh has its own wee tool but i have seen a universal thing that looks like half a normal valve spring compressor havent seen it bein used it must
bolt down somewhere or sumit
