devans414
posted on 4/3/10 at 01:27 PM |
Westfield SEiW 1700 XFlow (1993)
Due to the pending new arrival, I have no option but to unfortunately let the Westfield go.
It is a 1993 Westfield SE Wide Body, maroon in colour with a distinctive yellow band on the nose cone. The aeroscreen and front cycle wings are a
contrasting black, generally the body work is in very good condition.
Engine :
1700 Xflow engine out of a Caterham Supersprint. The engine is an AX block replaced by the previous owner prior to me owning it. The engine is in
excellent condition fitted with twin 40 DCOE's, a modified Aldon Automotive distributer, Aldon Ignitor and electronic ignition.
The engine was professionally setup and rolling roaded by Aldon Automotive in 2009, achieving 130bhp on the rollers.
Recently replaced the sump seals and fitted a newly modified shallow wet sump. It has a new waterpump, starter motor and 1Ltr alloy catch tank.
The oil has been changed every 6 months.
It has a Westfield 4 - 1 manifold and 5" Westfield exhaust with heat shield.
Fuel
New Facet fuel pump was fitted in Jan 2009.
Transmission
The car has got an uprated clutch, Ford 4 speed gearbox and a Sierra 4x4 Limited Slip Differential.
Suspension
AVO adjustable shockers.
CAT Motorsport wide track front suspension with poly bushes.
Wheels & Brakes
13x6" Minilites.
Disk brakes all on all four corners.
Braided hoses.
Race AP brake fluid.
Interior and Exterior
Westfield seats on runners.
Westfield 4 point harnesses.
Carbonmods Carbon Fibre dash.
Black aeroscreen.
Tailored tonneau cover (requires modification to fit over seats)
RAC rollbar.
Bootbox.
Electrics
New Odyssey Gel battery - Summer 2009
FIA cut off Switch.
4" headlamps.
Front LED indicators.
The Westfield is taxed end of the year and tested till mid 09.
I am looking for £5400
If you have any queries, please don't hesitate to contact me.
Pistonheads Advert
devans414
posted on 8/3/10 at 08:16 PM |
bump ![](/images//smilies/wink.gif)
perksy
posted on 11/3/10 at 08:44 PM |
All the Best with the Sale Mate
![](http://i114.photobucket.com/albums/n250/squirrelsbiscuit/100_1259.jpg)
