phil4521
posted on 7/3/10 at 04:03 PM |
New poly bushes for Viento
I took my front suspension apart earlier to check the bushes- decided to use to a power sander to take a few thou off as front were too tight- big
mistake- taken much too much off. I need a new bushes and then I will get a machine shop to do it..... - I think they are same size for all
suspension components? can anyone give me a part number and source so I can make sure I get right size replacements? Thanks
Phil.
Steve Lovelock
posted on 7/3/10 at 05:23 PM |
How much did you take off? I took loads off my Velocity's bushes, say 3mm each, and they work just fine. Could you not re-fit them and see how
they go? Otherwise call Ben at Luego who I am sure will be happy to sell you some more.
Regards
posted on 7/3/10 at 06:26 PM |
IIRC I took about 0.030" off the outer (larger) end. If I were doing it again I would use longer crush tubes
Bigheppy
posted on 7/3/10 at 07:02 PM |
Just put a large washer between the bush and mount, Job done and locost ![](/images//smilies/bigsmile.gif)
Paul (Notts)
posted on 7/3/10 at 07:11 PM |
If its only one you need then I may ( not sure ) have a spare.
Andybarbet
posted on 7/3/10 at 11:19 PM |
Hi Phil, im not much help on where to get the bushes but i do have access to a lathe and work in Letchworth so your welcome to bring the bushes over
for me to shave a bit off if you want.
Ive got to do all of mine too at some point.
Regards Andy
phil4521
posted on 1/4/10 at 12:19 PM |
update...
Spoke to Ben at Luego and he told me he has adjusted the size of the crush tube to eliminate the need to shave the top hat bushes- have just ordered
some and will try it this weekend and let you know results. If only the original Luego owners were decent engineers.....
Ben was v helpful by the way-seems to know what hes talking about.
Andybarbet
posted on 1/4/10 at 11:01 PM |
Let me know how you get on but offer is still there if needed.
phil4521
posted on 5/4/10 at 05:23 PM |
Just completed this job just on one side this weekend- took much longer than I planned and had to take loads off- about 3mmm off each side of each top
hat but now it seems fine. next weekend I will complete the other front side ( now I know how not to do it) and then the backs. I found sanding the
crush tubes down so they were super smooth made things much easier.
I have split the plastic cover off the lower ball joint which I think is a VOSA and MOT failure- any idea where I can get a spare?
jollygreengiant
posted on 6/4/10 at 03:38 PM |
So did you get the replacement crush tubes or not. By your description it seems that you did not get new crush tubes from Ben.???
phil4521
posted on 7/4/10 at 11:29 AM |
I got new crush tubes from Ben they are 1mm longer but still too short hence I needed to take a load off the top hats as well to.So looks like this
problem persists for new kits alike.........
richard thomas
posted on 7/4/10 at 11:29 PM |
Shouldn't the crush tubes be the same length as the inside dimension of the wishbone pick-up brackets?
posted on 8/4/10 at 09:19 PM |
No the brackets should be wider apart than the length of the crush tube to allow for some castor adjustment but the crush tube should be slightly
longer than the overall length of the poly bushes so that the bushes aren't clamped restricting free movement of the wishbones. The Luego build
manual suggests tighten the wishbone bolts and then backing the nut off to allow the arm to move which is asking for trouble. Sorting out the crush
tube /bush issue makes the car so much nicer to drive with compliant suspension
richard thomas
posted on 10/4/10 at 11:35 AM |
Penny dropped....the washers grip the crush tubes in fore and aft location?
I have been wrongly assuming that the washers would slip over the crush tubes....
phil4521
posted on 12/4/10 at 08:10 PM |
update on this job- I completed the drivers side on Sunday morning- getting hang of this now but it does take time to take suspension off and then put
back together again.
Spoke to Ben about lower ball joint- looks like I was worrying about a split in the PVC outer covering which is packaging. So no problem.
Incidentally as I was tightening up the suspension I wondered about torque settings- are there any?
posted on 13/4/10 at 06:13 PM |
If you read the Luego build manual it recommends tightening the bolt up tight and the backing off until the wishbone can move. IGNORE!!. I would have
thought that something like 90nm would be about right for a 12mm bolt. Your not trying to do the job by bolting the wishbone on to test it everytime
you make an adjustment are you? Nipping the crush tube in a vice when assembled is a lot quicker way of doing it ( Ask Geoff)
ben lord
posted on 14/4/10 at 07:53 AM |
All,
I have said this before. The old Luego manual that you all have is wrong and misleading in a lot of areas. We did not write it and recommend that it
is thrown in the bin.
Regards
Ben
Luego Sportscars
PS See you all at Stoneleigh
wilkingj
posted on 14/4/10 at 09:29 AM |
quote: Originally posted by ben lord
All,
Regards
Ben
Luego Sportscars
Thanks for that, Where can we download the updated build manual so we can check or cars are built properly? It does not appear to be downloadable on
the Luego website (I cant find any downloadable documentation relating to any of the builds)
I would have thought this would have been useful to prospective customers, as well as old ones.
I would be interesting to know how many uncompleted Luegos there are ot there.
Like all Kits many do not get completed and languish in garages and barns for years! ie how many are out there with still to be built using the old
manuals.
Just my 2d's worth.
EDIT:
Re Rustys comment about me!
If you have to shave off the poly bush, then test by assembling the bush in the arm and then nip it up in a vice and check to see you have free
movement. Reassembling on the car every time takes ages! (Guess how I know )
The Vice nip test will tell you when you are close enough for finally checking on the car.
Take it easy and steady, and dont rush it.
Finally the M12 bolt should be done up tight to hold the crush tbe tightly. If the bolt is loose it will move and wear the bracket holes oval. This
will mess up the suspension, and will eventally be a MoT failure point. Then it will need the brackets to be replaced.
[Edited on 14/4/2010 by wilkingj]
Best Regards
Geoff
http://www.v8viento.co.uk
