Author: Subject: Type 9 Gear Extender Problem
Bumble
posted on 7/3/10 at 08:07 PM Reply With Quote
Hi all.....bought a Westy remoteextender but I have a problem as you can see from the pic. The lever/link just touch the UV joint on the prop (heavy duty type UV).
Now I can probably gain at least 6mm by a combination of re-making the rear part of the shaft, spacing the unit up a nats from the box and spacing the lever up from the remote.
Just wanted to check there's not something simpler I've missed as brains a bit fried trying to work out new Premier Wiring Loom!!
Thanks all,
Bumble
posted on 7/3/10 at 08:09 PM Reply With Quote
Oh.....in my haste I forgot to ask.....would 6mm ish clearance be Ok??
Thanks.
flak monkey
posted on 7/3/10 at 08:16 PM Reply With Quote
You only need 2-3mm ish of clearance, nothing can move as long as there is no flex in the extension.
Sera
http://www.motosera.com
FrankP
posted on 7/3/10 at 08:22 PM Reply With Quote
Looks a it close - my one isn't that close. It looks a bit bent..
The other thing does n't it need the pastic rocker mechanism otherwise the lever wont engage..
Frank
RichardK
If it was me I would replace the extender shaft and lengthen the whole extender so it misses, it will also bring the gear lever a bit further back which maybe a a bit better, depends how big/small you are.
I made my own extender and its a lot longer, pictures are in my gallery somewhere with the measurements I used.
I wouldn't like a prop gap of 6mm if using rubber engine mounts. fixed mount racing car it'd be ok. But not in a road car in my opinion.
Rich
Gallery updated 11/01/2011
irvined
posted on 7/3/10 at 08:35 PM Reply With Quote
Had the same problem, used a piece of 2mm alloy to act as a spacer. To begin with I used a couple of washers on each bolt and that worked fine too.
http://irvined.blogspot.com
deltron63
posted on 7/3/10 at 08:49 PM Reply With Quote
i used a 3mm spacer
Bumble
posted on 7/3/10 at 08:55 PM Reply With Quote
Frank
Hi Frank...it's not bent...just my ace photo skills making it look like it is. What plastic bit are you referring to.....if you mean the plastic ball joints etc it has a short shift kit fitted and there is a 10mm spacer which you can just see in the photo which hides it all.
Let me know.
Matt
boggle
posted on 7/3/10 at 09:06 PM Reply With Quote
i fitted the saddle clip from my original transmision bit on to the extended bit...
u2u me for details
Bumble
posted on 7/3/10 at 09:08 PM Reply With Quote
Saddle clip???? Got any pics?
Thx.
Bumble
posted on 7/3/10 at 09:10 PM Reply With Quote
RichardK
posted on 7/3/10 at 09:17 PM Reply With Quote
Saddle
redscamp
posted on 8/3/10 at 01:29 AM Reply With Quote
is the prop shaft far enough into the gearbox?
does not look right to me
posted on 8/3/10 at 07:12 AM Reply With Quote
Jolly greengiant had this problem , it turned out that the prop U/J was larger than most IIRC
Bumble
posted on 8/3/10 at 09:12 AM Reply With Quote
Yep it's fine 25mm clear which is what the prop manufacturers recommend.
antwan
posted on 9/3/10 at 11:28 AM Reply With Quote
Yep same problem here. I found a 2mm spacer did work the problem being the higher you space the extender, the closer together your selections become. For example my 1st gets very close to reverse and you needed the nack to select 1st.
Depends on how much clash. If you dont have too much power maybe a smaller knuckled prop would be the answer.
