westy turbo
posted on 8/3/10 at 09:15 PM |
Cossie T5 oil amount,and 7"LSD
Hi,i would like to know how much oil goes into the T5 box,and how much oil goes at the 3.62 LSD diff and a good quality for them
flak monkey
posted on 8/3/10 at 09:18 PM |
Castrol GL5 oil for the Diff something like 75w-90 or similar.
Castrol ATF for the box.
Sera
http://www.motosera.com
westy turbo
posted on 8/3/10 at 09:23 PM |
Thanks! quantity?
flak monkey
posted on 8/3/10 at 09:29 PM |
This is from memory....
Diff is around 1.4 litres - basically fill to the hole in the back cover.
Box is about 2.5 litres
Basically you should need 2 bottles of oil for the diff and 3 for the box.
Sera
westy turbo
posted on 8/3/10 at 09:32 PM |
Cheers man!good luck with your build,iam having the same inlet builded for my turbo set up,and is for powercoating.
All my best again
[Edited on 8/3/10 by westy turbo]
