dan_g8
posted on 14/3/10 at 10:39 PM |
rover v8 gearbox advice
im currently looking about for a gearbox for my rover v8 powered haynes roadster.
Am i right in thinking that i can connect a Triumph tr7 gearbox to my engine? the tr7 gearbox is a lt77 would i just need to buy a rover v8 bell
housing?
im looking at a p6 gearbox aswell but this would be my last choice as it only has 4 gears!
Thanks,
Dan
[Edited on 14/3/10 by dan_g8]
RichardK
posted on 14/3/10 at 10:43 PM |
I have no idea but a quick search revealed a couple of thread, this being one of them that has a little bit of info that may help.
Linky
Rich
Gallery updated 11/01/2011
t16turbotone
posted on 15/3/10 at 07:08 AM |
Yes, any lt77 gearbox will fit with the right bellhousing, The lt77 that was fitted to the sd1 vittesse had stronger internals and slightly different
ratios. There is another gearbox for you to consider, the R380 which was fitted to some of the land rover discoverys is generally considered a
stronger and better box
nike5
posted on 16/3/10 at 09:48 PM |
Think that the T5 'can' offer you better ratios (depending on which one you go for).
As with a relatively light weight car a short first gear is not what you want.
