Author: Subject: Pictures of rear brake hoses fitted
locostbuyer83
posted on 16/3/10 at 08:13 PM Reply With Quote
Hey,
has anyone got any pictures of their rear brake hoses fitted?
I'm trying to fit mine and not sure how much slack to leave for suspension movement etc.
gordon h
posted on 16/3/10 at 08:18 PM Reply With Quote
pop up the farm sometime and have a look at mine.
bec is best but going to try sabb 2.3 turbo mk
Daddylonglegs
posted on 16/3/10 at 08:29 PM Reply With Quote
Heard that one before! It'll be the puppy collection next
asn163
posted on 16/3/10 at 08:43 PM Reply With Quote
Does this help?
MautoK
posted on 17/3/10 at 12:17 AM Reply With Quote
The bracket on the hub carrier looks somewhat flimsy, if I may be so bold.
A few hundred miles of shock and vibration is likely to see that bend or fracture with consequences on the bundy!
Just my 0.02c...
John.
Bluemoon
posted on 17/3/10 at 11:08 AM Reply With Quote
if you take the springs off the shocks you can then check with the full travel that you chosen position works.. Worth trying as where the hoses go and if they are under strain is difficult to tell without checking.. Good time to check wheel fouling of rear cycle wings as well...
Dan
locostbuyer83
posted on 17/3/10 at 09:05 PM Reply With Quote
Do you need a bit of copper pipe at the wheel end if you have rear calipers?
Originally posted by asn163
Does this help?
posted on 17/3/10 at 09:34 PM Reply With Quote
