karlak
posted on 18/3/10 at 08:15 PM |
Headlight Mounts - MK Indy
My Mk has been built with a steel bar that goes across the top of the chassis - The headlights are mounted on the end of this. However, I have seen
that some have a more dedicated headlight bracket mounted on each side. Were these stndard fit and the steel bar of mine a builder option ?
If so can the Bracket sbe bought and fitted to any MK chassis .
cheers
MK Indy - 2litre Duratec - Omex 600 - Jenvey throttle bodies - ETB DigiDash2
posted on 18/3/10 at 08:22 PM |
MK standard fitment always used to be a bar bolted across the top chassis rails wit a round part on each end for SVA rads. Only downside was the need
to cut a slot in the nose cone to clear it.
IMHO it would have been neater to weld a short sub on each side on to the sides of the upper chassis rails. A few grams lighter too ![](/images//smilies/wink.gif)
Breaker
posted on 18/3/10 at 08:24 PM |
My Indy R chassis has just 2 short pieces on the sides.
StevieB
posted on 18/3/10 at 08:31 PM |
My standard Indy has 2 short stubs too.
Personally I would have preferred the bolt on bar so the lights would be easily removable for trackdays etc.
posted on 18/3/10 at 08:36 PM |
...there you go then, looks like they adopted my wishes ![](/images//smilies/wink.gif) ![](/images//smilies/bigsmile.gif)
