New Topic New Reply
Author: Subject: Locost new build
The Ssssnake
posted on 19/3/10 at 10:08 AM Reply With Quote
Locost new build
Hi guys, anybody out there in the Shrewsbury area willing to give some much needed advice on where to start???
Have purchased chassis complete with wishbones and wondering where to go next with build.
daniel mason
posted on 19/3/10 at 10:11 AM Reply With Quote
what chassis have you bought? pre built or need welding!
[Edited on 19/3/10 by daniel mason]
The Ssssnake
posted on 19/3/10 at 10:28 AM Reply With Quote
Pre built, but will need a few bits and pieces adding I think. Had a look at buying the steel from Talon motorsport but bottled it!! Decided to buy an aborted project. Could do with advice on how best to organise build
Big Stu
posted on 19/3/10 at 10:34 AM Reply With Quote
I would start by checking all the welds on the chassis and reweld them if required, check the geometry is all correct. Thats where I'm up to at present after this I was going to do the following.
Give the chassis a lick of paint.
Fit axel.
Install front suspension.
Steering rack and column mounting
Engine and Gearbox trial fit
Bodywork trial fit
Then everything else.
[Edited on 19/3/10 by Big Stu]
stevec
posted on 19/3/10 at 11:22 AM Reply With Quote
There are quite a few build diarys in the links section on here at the top of the page, perhaps have a look through and you will get a general idea of the way forward.
Take your time to do the research it will make the job easier. And as said check your chassis is OK first.
Cheers.
Steve.
plantman
posted on 19/3/10 at 08:02 PM Reply With Quote
trial fit every thing weld aditional brackets etc
then prep every thing for spraying etc
then brake lines fuel lines
re fit
have fun
i am 15-20mins from shrewsbury
New Topic New Reply
