rsmith95uk
posted on 31/3/10 at 03:19 PM |
Bike Carbs/Choke Cable
just got around to fitting a choke cable to my ZX6 Carbs & the solderless nipple is catching on the body of the carb meaning I can only open the
choke less than half its travel.
I assume that the solderless nipple I'm using isn't suitable, but to save me time (& effort - I'm a lazy b*****d) searching, can
someone point me in the direction of one that'll work?
Ray
Slater
posted on 31/3/10 at 03:50 PM |
Cut the nipple off and use the metal bit from the inside of the chocolate block electrical connectors.
blakep82
posted on 31/3/10 at 03:54 PM |
erm, but the cab;e enters from the wrong angle how does that work?
if you can get the cables off a bike, that would be better. even a cycling shop should have something suitable
________________________
whitestu
posted on 31/3/10 at 03:55 PM |
Cut the nipple off and use the metal bit from the inside of the chocolate block electrical connectors.]
Me too.
[Edited on 31/3/10 by whitestu]
gdp66
posted on 31/3/10 at 04:57 PM |
i think i used a universal bicyle brake cable.
rsmith95uk
posted on 1/4/10 at 05:40 AM |
thanks for the responses chaps - have ordered a ZX6 choke cable - need to see it in front of me to determine how/if I can use it.
Ray
