Author: Subject: Crusty Tig Welds
mistergrumpy
posted on 31/3/10 at 07:05 PM Reply With Quote
Crusty Tig Welds
I've startd having a go at welding some bits of stainless exhaust togethr and I seem to be getting a lot of crusty welds with a yellow/light brown appearance. I figure it may have somethig to do with th Argon coverage. I have a rubber tube coming off a y splitter straight from the welder output which I put into the exhaust pieces to back purge them but it was still there, though admittedly less.
Can anyone confirm if I'm right in what I'm thinking?
Breaker
posted on 31/3/10 at 07:11 PM Reply With Quote
Are the crusty parts on the backside of your weld pool? If so, you should supply more argon to the backside of the weld pool. Just leave as small opening so there can be no build up of pressure which will make your weld pool bubble.
[Edited on 31/3/10 by Breaker]
mistergrumpy
posted on 31/3/10 at 07:17 PM Reply With Quote
No the crust is on top.
Breaker
posted on 31/3/10 at 07:27 PM Reply With Quote
Did you degrease the material ?
Are you sure it is 100% Argon and not a Argon/CO2 mixture ?
Is the tungsten electrode clean ?
mistergrumpy
posted on 31/3/10 at 07:32 PM Reply With Quote
Didn't de-grease it, just wire brushed it.
100% Argon, works fine with aluminium
Tungsten clean and sharp.
Breaker
posted on 31/3/10 at 07:40 PM Reply With Quote
Sorry, I've never seen this kind of crusty weld on the weld pool side...
AC-DC setting OK ?
Gas flow OK, not blocked ?
What happens if you make a weld pool without adding material ? (perhaps the adding material is not clean/same material as the stainless pipe ?)
mistergrumpy
posted on 31/3/10 at 07:49 PM Reply With Quote
Its strange. When the current was too high it appeared worse but the current is under control now. The weld appears fine when welding but then when I stop welding it starts to yellow/brown.
deezee
posted on 31/3/10 at 08:20 PM Reply With Quote
You might as well list all the settings. Whats your flow rate, amperage, how is your torch set up, what grade is your filler?
Whenever I've seen that kind of welding its been due to incorrect gas flow or wrong gas (argoshield light)
Davey D
posted on 31/3/10 at 11:03 PM Reply With Quote
In between dips are you pulling your filler rod out of the gas shielding? If you are it could be oxidising, this could explain the discoloration of the surface of the weld
907
posted on 1/4/10 at 08:19 AM Reply With Quote
IMHO
If I understand you correctly you have connected into the argon line to the torch that comes from the welder???
Neither flow is controllable done in this way. The gas will just take the easy path and as you weld up the joins then flow rate will change.
What you need is a Y or tee at the regulator with flow meters so you can control the individual flow rates.
e.g. 6 L/min purge, 9 L/min to the torch.
This will also enable you to purge for a couple of minutes before you start welding.
If I have misunderstood then ignore this post.
mistergrumpy
posted on 1/4/10 at 05:38 PM Reply With Quote
No no that actually makes a lot of sense Paul. I have a tee on the welder output.
Regards the settings, I'll have to go outside later but I think Paul's right there plus I haven't been pre purging and from reading last night I think I should have been plugging the open ends of the exhaust up with a small opening for venting pressure.
I'll have to try again later.
I'm sure the gas is fine it works well with aluminium and was sold as pure Argon.
907
posted on 1/4/10 at 07:38 PM Reply With Quote
Yes, you must block off the ends.
For 2" pipe I use a 2" disc of thin metal that has a hole in the middle ( 1/4" ) that is the same size as my purge tubing.
I push the tube through the disc and tape the disc to the end of the pipe to be welded.
The other end I block with a 2" disc that has a 3mm hole in it and tape this on.
If you have any gaps in any joints then 1" masking tape over the joint will stop you losing the argon.
Just peel off the tape for the joint to be welded, weld, then peel off the next one.
The inside should look like the one in the pic.
HTH
