Author: Subject: Water wetter ?
Jon Ison
posted on 4/4/10 at 05:21 PM Reply With Quote
Water wetter ?
Used it before with good results, but whats it make up ?
At a tenner a bottle are the ingredients available off the shelf ?
RIE
posted on 4/4/10 at 05:31 PM Reply With Quote
Some photographers (well, film developers) used a water wetter product to wash a film once it's been developed. It reduces the surface tension of the the water, and apparently the same effect can be achieved with washing up liquid. I don't know if it will work for your application, but it's an idea.
tonym
posted on 4/4/10 at 05:40 PM Reply With Quote
I was told you can use fabric softener but have not had the courage to try it. Surely washing up liquid would foam causing cavitation and many other problems
jacko
posted on 4/4/10 at 05:52 PM Reply With Quote
I would not try this you can if you wan't
but a old Mechanic once told me to put cutting oil in the water [only a small amount ]
I don't know if it works dose any one else know
Jacko
posted on 4/4/10 at 06:01 PM Reply With Quote
Jacko
Thats an old trick from marine engines to reduce corrosion I would advise against as it actually reduces heat transfer.
serieslandy
posted on 4/4/10 at 07:40 PM Reply With Quote
Ten quid vs cost of new engine. I know which one I would go for.
v8kid
posted on 4/4/10 at 09:56 PM Reply With Quote
Dishwasher tablet
Cousin Cleotis
posted on 4/4/10 at 11:04 PM Reply With Quote
Surely it must have some information on the label in case some e silly sod drinks it?
Paul
posted on 5/4/10 at 06:48 AM Reply With Quote
Originally posted by v8kid
Dishwasher tablet
I used some dishwasher powder once to flush out the cooling system on a K series engine when everything else failed, not sure if it reduced the surface tension of the water .
