cosmick
posted on 5/4/10 at 09:15 PM |
Anyone know if I can get 10mm x 1.0 x 40 long bolts
Can anyone help me locate some longer bolts for the Sierra propshaft to diff? I need to make a spacer to lengthen the propshaft by 30mm and i figured
that if I could make a flanged joint, I could bolt it up to the diff between the prop and diff. As it is a special thread, I need 4 extra long bolts.
Any ideas?
If it can't be fixed with a hammer then its probably an electrical problem.
Lars
posted on 5/4/10 at 09:22 PM |
I tend to get bolts from Namrick
See below, they do M10 x 1 x 50
It is 8.8 strength, which should be enough, but original bolts are stronger, 10.9 i think
http://www.namrick.co.uk/browse.asp?PCID=9
matt_gsxr
posted on 5/4/10 at 09:23 PM |
you could e-bay this:
M10 x 45 SUPER FINE PITCH 1mm ALLEN CAP 12.9 BOLTS 4PCS
Ridiculous price, but nice and easy to order with paypal!
or Namrick
namrick
59p a bolt, not sure of postage.
Matt
cosmick
posted on 5/4/10 at 09:27 PM |
Thanks for the prompt reply and the link, I will give them a go.
Lars
posted on 5/4/10 at 09:30 PM |
Matt you are right, I was looking at set screws.
