New Topic New Reply
Author: Subject: Cheap Noise Meters
fishywick
posted on 12/4/10 at 09:30 AM Reply With Quote
Cheap Noise Meters
I am looking at a noise meter to try and prevent any problems at trackdays.
My Striker passes no problem at 96dba but I am considering some of the Croft low noise days at 88dba with A N other car.
I see there are lots of meters on fleabay for £20 upwards, are they reliable?
boggle
posted on 12/4/10 at 09:43 AM Reply With Quote
i had one on my nokia phone...
u2u me for details
RichieHall
posted on 12/4/10 at 10:19 AM Reply With Quote
Not particularly accurate but....
http://www.maplin.co.uk/Module.aspx?ModuleNo=226470
Rust is lighter than Carbon Fibre!
dhutch
posted on 12/4/10 at 10:39 AM Reply With Quote
My housemate (on here also) had a cheapish DB meter (cant tell you the brand/age/cost sadly) but it was 6 db out when held side by side to the one being used on my exhaust at snetterton.
Clearly for comparative work it still works, but certainly it highlights the sort of accuracy you can be working with prehaps.
Danel
Bluemoon
posted on 12/4/10 at 10:55 AM Reply With Quote
Good price, just to need to compare it to a calibrated one (or maybe SVA value if that was not long ago)....
Dan
RIE
posted on 12/4/10 at 11:35 AM Reply With Quote
6dB is a hell of a lot to be out, the exhaust is 4 times louder (or quieter) than the meter indicates
ashg
posted on 12/4/10 at 11:37 AM Reply With Quote
i have got this one.
http://www.maplin.co.uk/Module.aspx?ModuleNo=46362
you can get them on the bay for a lot less
have compared it to a proper calibrated cirrus one (same as what they use for iva). both read the same when using the calibration device which is impressive as the cirrus ones are well over £500
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
fishywick
posted on 12/4/10 at 11:52 AM Reply With Quote
As usual, once the research starts, it all gets ever more complicated...
"Its important to note that this sound level meter reports only the ‘C’ weighed total sound level. ‘C’ weighting treats low and high frequencies equally - which you might imagine was just what you wanted do do.
However the ear is not very sensitive to low frequencies and so estimates of noise annoyance normally use the ‘A’ weighted measurement which reflects the ears insensitivity to quiet low frequency sound, sounds like distant trafic noise, air conditioning rumble etc. The Maplin unit doesnt have an A weighting option so you cant really compare the decibel sound levels it gives you with most published tables."
However it seems it may be worth a punt at £20 from what you say. The same meter from Maplin is available on fleabay in both A and B options.
fishywick
posted on 12/4/10 at 11:53 AM Reply With Quote
DM
posted on 12/4/10 at 12:02 PM Reply With Quote
I bought the maplin one then took it back when I realised it was no use. At least maplin are good with their refund
brands hatch measured me at 98db, the maplin one said something stupid like 114db
as mentioned, lot of difference between dbA and dbC
posted on 12/4/10 at 12:14 PM Reply With Quote
Not worth it except for relative dB checks IE fit a new exhaust and see if reads higher or lower than before.
Proper dB meters are seriously expensive bits of kit and need regular (and also expensive) calibration....
As said 6dB is quite a lot at the end of the scale we're talking about!!
dhutch
posted on 12/4/10 at 12:39 PM Reply With Quote
Yeah, its stack load.
- Mind you, i was 9db over to start with and got it down with wad load of wirewool...!
A weighted is what you want, should be what all tracks use, afaik. Certainly thats what we used at work for all noise testing of machines.
JonnyS
posted on 12/4/10 at 04:52 PM Reply With Quote
Cheap noise meters are useless to be honest. I bought one off eBay for £15 and it measured 110-120db when two 'expensive' meters measured 99db...
bigfoot4616
posted on 12/4/10 at 05:53 PM Reply With Quote
i've got one of these, think i payed about £40 for it and used it once.
i've no use for it now as i know i wont pass 98db so i'm sure we could sort something if its any use to you
GavR
posted on 11/5/10 at 12:05 PM Reply With Quote
I use my Iphone decibel meter, it was 59p. Dunno how accurate it is becuase I havent had any comparisons but Ive herd Topgear used it on a episode and was complementing it.
New Topic New Reply
