Mave
posted on 13/4/10 at 04:31 AM |
Input shaft diameter MT75??
as I was installing the Westfield release bearing in my MT75 gearbox, I noticed that there is a lot of play between the input shaft and the release
bearing. Completely different to the Type 9 gearbox with its releasebearing. Is that normal?
As I bought the Westfield MT75 releasebearing, I'm assuming that is correct. Could it be that the input shaft of my gearbox is smaller than
regular? Are there different versions?
Thanks,
Marcel
big_wasa
posted on 13/4/10 at 12:41 PM |
Its the same 1" 23 spline as the T9 and yes they are a touch sloppy
