rsmith95uk
posted on 15/4/10 at 08:55 AM |
Rad Hose
can anyone confirm whether the large hoses between Pinto Thermostat / Pump and Rad is 32mm or 38mm.
Ray
[Edited on 15/4/10 by rsmith95uk]
omega0684
posted on 15/4/10 at 10:23 AM |
themostat OD is 34mm,
Water pump housing is 40mm OD - i use a 40-34mm reducer straight off the water pump housing.
[Edited on 15/4/10 by omega0684]
rsmith95uk
posted on 15/4/10 at 11:35 AM |
thanks for that - now need to get browsing for the bits I need to fit my polo rad!
Ray
karlak
posted on 15/4/10 at 11:49 AM |
Ray
Keep us updated - This is on my list of things to do also.
MK Indy - 2litre Duratec - Omex 600 - Jenvey throttle bodies - ETB DigiDash2
James
posted on 15/4/10 at 01:56 PM |
I thought the thermostat outlet was 32mm? Which is the same as the Polo inlet/outlet isn't it?
I may be (probably am) wrong though but worth a measure to be sure I'd have though.
James
- Muhammad Ali
rsmith95uk
posted on 15/4/10 at 04:17 PM |
James - I think that is probably what omega0684 is suggesting. He has quoted the outside diameter at 34mm so the inside diameter will be 32mm (or
very close) which is probably what is quoted when buying hose.
Ray
blakep82
posted on 15/4/10 at 05:47 PM |
34mm hose is quite annoying. really struggling to find 35mm (the nearest) hose joiners at reasonable price. been buying hose off ebay, they have blue
in most parts, except the 35mm bits i need...
________________________
omega0684
posted on 15/4/10 at 07:40 PM |
Ray
you can use 32mm hose as it will be nice and tight around the thermastat outlet, i use one of
THESE (LINKY) and cut one side right down then stick a 90 degree bend after it, then a straight section, job done for
the top hose!
omega0684
Ray
the top hose!
