VinceGledhill
posted on 21/4/10 at 07:01 AM |
CBR1000 - No Spark
Wired it all up as per the wiring diagram in the bike manual and I'm not getting a spark at all.
Are there any common problems? What's it likely to be?
Regards
Vince Gledhill
Time Served Auto Electrician
Lucas Leeds 1979-1983
Guinness
posted on 21/4/10 at 07:36 AM |
What have you done with the sidestand / clutch / neutral switches?
VinceGledhill
posted on 21/4/10 at 09:03 AM |
I've not done anything with them.
Thanks for the tip. Sounds like all that lot should be connected. I'll have to look to see what they all do and give them what they need.
Do any of them switch to earth? Or do they all have feeds to them?
Surely taking it out of neutral shouldn't stop the car, if that was the case you could never drive anywhere.
Regards
Vince Gledhill
Guinness
posted on 21/4/10 at 09:06 AM |
On the ZZR the three switches act as a safety interlock, preventing you starting it unless you have it in neutral, or have the clutch in. I think it
is also set up to stop the sparks if the side stand is down when you let out the clutch with it in gear.
Something about NOT / AND switches.
HTH.
Mike
VinceGledhill
posted on 21/4/10 at 09:12 AM |
Thanks Mike, I'll look at it. Trouble is, the wiring diagram I have is in the back of the hanes manual and although good and in colour
there's a few models and not all the wiring diagrams are the same.
I don't know exactly which bike my engine is out of. Bought it second hand off a guy on here ages ago.
Regards
Vince Gledhill
jimgiblett
posted on 21/4/10 at 11:02 AM |
Is it just no sparks. The interlocks normally stop the starter rather than the sparks.
What year is the engine. If it is a recent one (ie fuel injected) it will need the Honda HISS components.
- Jim
VinceGledhill
posted on 21/4/10 at 11:50 AM |
Thanks for the reply Jim.
No it's the older one with carbs.
Regards
Vince Gledhill
jambojeef
posted on 21/4/10 at 11:51 AM |
On the CBR1000 the safety checks just stop the spark - you can turn the engine over as usual.
If you always want it to start (rather than when only in neutral) find the clutch switch and bridge its terminals.
That way when you stall pulling out into a stream of traffic you can restart without trying to find neutral with the engine off....you can guess how I
know that....
VinceGledhill
posted on 21/4/10 at 12:01 PM |
I've wired it all up without that lot fitted. Must have missed one of those interlocks.
I'll let you know how I get on tonight.
Regards
Vince Gledhill
JF
posted on 21/4/10 at 03:41 PM |
As said above the sidestand/neutral/clutch switch usually kill the starter, not the sparks.
But the emergency cutoff switch cuts the sparks. And on most bikes lets the starter go round. On motor meets there often is a 'funny guy'
who thinks it funny to let a few people start there batteries flat. As these switches are fitted to the handlebar.
Simple matter of soldering in and output together as it's a classic failsafe system.
Anyway good luck.
craig24
posted on 21/4/10 at 10:54 PM |
Have you used the bike ign key/switch on my zzr 1200 the ign switch drops the ecu feed voltage to 9.9 volts have a resistor fitted now but it wouldnt
spark with it wired with std 12 volt feed
craig
VinceGledhill
posted on 27/4/10 at 07:21 PM |
Thanks guys. Looks like it was one of the interlocks as indicated. There was a spare spade terminal with no wire to it.
I took best guess and put an earth to it, I now get a spark.
Please tell me, does it fire a spark on cylinder 1 and 4 at the same time? But only one is on the power stroke? That's what it looks like to
me anyway.
Regards
Vince Gledhill
Guinness
posted on 27/4/10 at 07:27 PM |
me anyway.
Pleased it sparks. Yes it is a wasted spark system. Pair of coils will do 1-4 and 2-3 or something like that!
tony-devon
posted on 28/4/10 at 07:47 AM |
yup as correctly stated already, it will run 2 coils, 1-4 and 2-3
as you said it runs on wasted spark, the ignition barrels on a lot of the kawasakis do indeed have an extra wire, most commonly its grey, it doesnt
always appear on the wiring diagrams for some reason in my experience, but the genuine barrels have a resistor that drops the voltage, without this
the CDI wont work.
you can just rewire the engine very minimally and its what I do with mine, generally for all custom bike applications I wire lighting circuits,
charging, ignition, and starting on their own fuses and sub wiring loom, easier to fault find, and also far less hassle.
if you look through the wiring diagrams you can very easily start to see whats needed and what isnt, its normally very easy to reduce it to just the
cdi connected to coils, power and the pickups on the engine, generator to rectifier, with power connections and on some models a voltage sensing
wire.
then a simple starting circuit for the solenoid and starter motor
the newer fuel injected sports bike engines are more involved but its still simple to break the wiring down
if on doubt print off the wiring diagram you need, then blank or tippex out the gubbins you deffo dont want, then photo copy this.
heavy is good, heavy is reliable, and if it breaks, hit them with it
