Author: Subject: HELP PLEASE!!Wishbone Bushes front and rear for Locust Roadster (Chris Gibbs Edition)
locustzetec
posted on 22/4/10 at 06:17 PM Reply With Quote
Hi, im new to this website, but i was hoping someone could help me. Im trying to find out which poly bushes to use and where to buy them from? The Bushes i require are: Wishbone Bushes front and rear for Locust Roadster (Chris Gibbs Edition).
Minicooper
posted on 22/4/10 at 06:32 PM Reply With Quote
3GE supply components for the Haynes Roadster (Chris Gibbs)
http://www.3gecomponents.com/templates1/view_product.php?product=391&site=63&department=116
locustzetec
posted on 22/4/10 at 06:40 PM Reply With Quote
Thank you for the help! is this 3Ge components the only place to these bushes? I only ask, as this seems a little pricey! but its not a problem they are the only place! cheers matt
tomprescott
posted on 22/4/10 at 06:45 PM Reply With Quote
They aren't pricey at all, you're getting a lot of high quality bush, if you look at polybush kits for tintops you'll see they cost around £70 and up per axle!
A bird in the hand....
locustzetec
posted on 22/4/10 at 06:53 PM Reply With Quote
To be honest I think its a reasonable price, but my dad(who im building the car with), thinks its expensive! but being as im paying for them, i might just get them anyway! What coilovers do builders generally use? Ive just bought a set of gaz coilovers for mine.
dogwood
posted on 22/4/10 at 06:57 PM Reply With Quote
I think you can also get the bushes from Rally Design.
Doubt they'll be any cheaper though
FREE THE ROADSTER ONE…!!
tomprescott
posted on 22/4/10 at 07:01 PM Reply With Quote
Gaz are used regularly but I've been hearing a lot about gaz struts leaking recently (have a search and you'll see what I mean) then again, lots of people have them and haven't had problems. Good luck with the build.
Minicooper
posted on 22/4/10 at 07:05 PM Reply With Quote
The Rally Design bushes I have are 46mm stainless steel crush tubes to suit 1/2" bolts not 44mm crush tubes and 12mm bolts as the haynes Roadster uses.
One thing I'm not keen on is the 3GE bushes are rock solid!
Tatey
posted on 22/4/10 at 08:30 PM Reply With Quote
Saturn Sports Cars also sell them, both Andy's are a great pair and will go well out of their way to ensure you have a good experience with their products.
locustzetec
posted on 22/4/10 at 08:57 PM Reply With Quote
do you know the website?
dan_g8
posted on 22/4/10 at 09:25 PM Reply With Quote
http://www.saturnsportscars.co.uk/store/index.php?_a=viewProd&productId=54
skinned knuckles
posted on 23/4/10 at 07:45 AM Reply With Quote
i bought the gaz shocks and to be honest, the plating has started to look like its failing and they arent even on the car yet
A man isn't complete until he's married, then he's finished
tony-devon
posted on 11/5/10 at 08:26 PM Reply With Quote
did you have any joy with 3GE ?
just asking as been trying to contact them but they dont reply to emails?
damned annoying as I need to order bushes, but dont want a full set, only enough to do the rear, been asking them about hardnes and stock of wishbones etc for a few days but no reply
heavy is good, heavy is reliable, and if it breaks, hit them with it
