flak monkey
posted on 24/4/10 at 07:37 PM |
Modifying sierra handbrake mechanism
I will need to modify the handbrake mechanism on my sierra calipers, or find an alternative fitment, to fit them under the 13" CXR's I am
going to fit.
I have to keep everything withing 154mm of the axle centreline
I make the handbrake lever and spring 158-160mm from the centreline so I need to squeeze 4-6mm off somewhere
Pics would be good
Sera
http://www.motosera.com
bigrich
posted on 24/4/10 at 09:34 PM |
David, remove the stock spring and replace with a compression spring over the cable between the lever arm and cable retainer of the caliper. you can
also gain a little more clearence by bending the lever arm of the caliper down slightly.
hobbsy
posted on 24/4/10 at 09:56 PM |
I also need to do this. Where did you source the new spring? Got any photos? Thanks.
bbwales
posted on 24/4/10 at 10:16 PM |
I have just done this and got my springs from a drum brake sierra, I used the hand brake springs where the cable enters the drum, had to cut them but
no probs and it seems to work fine.
Regards
Bob
James
posted on 24/4/10 at 10:57 PM |
Seconded with photo request. Having trouble picturing what you mean Bob!
James
- Muhammad Ali
bbwales
posted on 24/4/10 at 11:05 PM |
I will take some pics tomorrow and try and post them, but be warned I do have a problem with that.
Regards
Bob
JonnyS
posted on 27/4/10 at 06:55 AM |
RJK350 has just had a batch of shortened springs made with only 3 coils, I had a pair. He may have some left.
bbwales
posted on 27/4/10 at 08:11 AM |
Hi I have put a couple of pics on in my area, will try to upload them here but please don't hold your breath.
Bob
MY god I did it, the springs are from a Sierra drum brake cable.
[Edited on 27/4/10 by bbwales]
![](/galpreviews/a1138567-Brake spring1.JPG) ![Rescued attachment Brake spring1.JPG](/gallery/a1138567-Brake spring1.JPG) Rescued attachment Brake spring1.JPG
hobbsy
posted on 27/4/10 at 01:08 PM |
Let me just turn my photo around so its the right way (original post above deleted):
![](/galpreviews/a1138703-rear.jpg) ![Rescued attachment rear.jpg](/gallery/a1138703-rear.jpg) Rescued attachment rear.jpg
JonnyS
posted on 27/4/10 at 05:36 PM |
So you need a 3 coil spring (or spring on cable) and to bend the arm down slightly. Yours looks exactly like mine did.
hobbsy
posted on 28/4/10 at 05:22 PM |
I'm getting a pair of 3 coil springs from RJK350.
I'll post up an "after" photo when I get them fitted.
May have to just touch the outer part of the spring mech with the angry grinder (or a file).
JonnyS
posted on 28/4/10 at 06:36 PM |
Bending it is easy, just put a screwdriver in the hole on the arm and pull down gently.
hobbsy
posted on 28/4/10 at 07:39 PM |
Oops I'd forgotten you'd said that.
I'll do that then! ![](/images//smilies/smile.gif)
