rich201283
posted on 27/4/10 at 02:35 PM |
Fiesta brake master cylinder(non servo)?
I have a fiesta brake master cylinder with 4 outlets, 2 are a different size to the other 2, Is it better to run 4 separate brake line to each wheel
or only run 3 and block one of? also does it mater which goes to which wheel
Dick Axtell
posted on 27/4/10 at 04:42 PM |
If its a kosher Fiesta mcyl, there should be a 50:50 split between primary and secondary chambers. Fiesta brakes were connected in X-split (i.e. L/H
front to R/H rear, R/H front to L/H rear).
Primary = nearest to pedal,
Secondary = furthest from pedal.
Check out the displacement vols for your brakes cyls.
rsmith95uk
posted on 27/4/10 at 05:14 PM |
Hi, replaced my sierra m/c with one of these (bought from lurch88 off here) which had the larger outlet at the pedal end blanked off with a bleed
nipple. I used the other 3 outlets and the car has just passed its MOT without any issues.
Ray
matty h
posted on 27/4/10 at 08:13 PM |
Could use the fourth port for a brake light switch.I have fitted one of these gives more padal movament ans less effort because of the smaller bore
size.
mistergrumpy
posted on 27/4/10 at 08:45 PM |
I've done as RSmith too with the bleed nipple. Far better response than a Sierra MC.
