andrew_s
| posted on 11/5/10 at 08:06 AM |
Switch layout and Immobliser
Hi
I am currently building an MNR Vortx, is there a good way to lay the savage switches out on the centre tunnel, or is it whatever you are happy with -
anything specific for iva ?
On the iva - do you have to have an immobiliser ? in the iva book it says it has to be installed with a certificate - does this mean you cannot do it
yourself - this is something i am more than capable of doing, however happy to sub it out to a local alarm firm if it means passing the iva
Lastly – do your indicator switches have to have symbols on them, my savage switches are blank for the indicators, obviously i will get a visual
indication on the dash
Thanks in advance for any replies
eznfrank
| posted on 11/5/10 at 08:23 AM |
Yes you have to have some form of immobilisation device, can be electronic or mechanical.
Where does it say immobiliser has to be installed with a certificate?? Just seems a bit of an odd question to ask "does it have to...."
and then "it has to be....."??????
If you want symbols for your savage switches contact sales@apem.co.uk, they sent me some FOC
iank
| posted on 11/5/10 at 08:28 AM |
It used to say it had to be installed by a professional, but it's been relaxed in the latest version of the manual I have (version 4).
http://www.businesslink.gov.uk/Transport_Theme_files/124_IVA_M1_Inspection_Manual__Version_4.pdf
If you look at the change record in Section 13A you can see
"Remove the requirement of documentary evidence for the immobiliser" dated 29/06/2009
On the layout of switches, so long as the pass projection tests, are reachable and if you are using the lights for tell-tales are visible while
strapped in they should be fine.
[Edited on 11/5/10 by iank]
Anonymous
andrew_s
| posted on 11/5/10 at 10:11 AM |
Great, thanks for the replies, I will install an immobiliser myself, and work out some sort of switch design, seems sensible that you should be able
to reach them and see the tell tales !
I will download version 4 of that manual as well, clearly I was looking at an out of date version.
