Author: Subject: LT77 Gearbox bearing issue
darrens
posted on 17/5/10 at 05:41 PM Reply With Quote
Hope someone could shed a bit of light before I remove it.
If the car is in neutrel and the clutch is release there is a definite bearing whine, depress the clutch and it goes away.
Anyone throw a bit of knowledge into likely culprit or am i better just taking the box out and sending off to someone.
Lightning
posted on 17/5/10 at 06:05 PM Reply With Quote
My TVR does that but not a whine but a sort of rumble banging and a sound of gears trying to enter the cockpit. Its going for rebuild in 2 weeks LT77 too
tomgregory2000
posted on 17/5/10 at 06:35 PM Reply With Quote
just sounds like the release bearing needs changing
posted on 17/5/10 at 07:08 PM Reply With Quote
Unlikely to be the release bearing
Sounds like one of the needle rollers in the box main shaft these boxes are really sensitive to the correct lubrication -- correct level and oil grade ideally MTF94 at a pinch Dextron ATF or 10w/40 engine oil as a 3rd choice..
darrens
posted on 17/5/10 at 08:27 PM Reply With Quote
I agree, unlikely to be release bearing as it would wine with clutch depressed.
It also wines when driving.
Looks like it's coming out!!
Cheers for replies
