Author: Subject: whats the easiest route to go down? clocks, wiring?
buncefm
posted on 20/5/10 at 06:36 PM Reply With Quote
ive got 2ltr zetec so whats the best route to go down in regards to clocks and wiring, what are my options? could i use mondeo clocks?
dhutch
posted on 20/5/10 at 07:30 PM Reply With Quote
If it where me, get a set of second hand VDO's or similar. Ive never had any experience of using oem clocks outside of there car but even if its easy there always going look like where they came from.
Daniel
RazMan
posted on 20/5/10 at 08:01 PM Reply With Quote
The easiest option is to buy an all-in-one dash like the Evodash, Stack etc which have all you need in one, compact display. The trade off however, is cost.
Raz
bi22le
posted on 20/5/10 at 08:15 PM Reply With Quote
Money dependent obviously.
If your car is a modern engine and you want the modern look I think ETB Digidashes are hard to beat. They look trick and work well. The set comes with all of the senders you need aswell.
Stack are the dogs meaty bits but they cast a stack of money. . . Ha ha. . . sorry
There are others like Viper but my mate had right trouble setting one up and gave up in the end.
Tradition look is always the dialed style. They look trick, you can choose the style, fitment, colour and size. Alot more versatile depending on what look dash your trying to achieve.
All should work with you car and electronics.
HTH
Please read my ring story:
a4gom
posted on 20/5/10 at 08:21 PM Reply With Quote
Never used them but I was looking at these before I went bec and used the bike clocks here
Perfect planning prevents pi$$ poor performance!
blakep82
posted on 20/5/10 at 09:25 PM Reply With Quote
RMD gauges are pretty decent. get them from rally design.
modeo gauges are most likely going to need some sort of recalibration at some point. some functions probably need the original ECU.
________________________
mgmiller
posted on 20/5/10 at 10:29 PM Reply With Quote
I had a ETB digidash in my Viento.
It was well built and easy to wire but my major gripe with it was that you could not program the screens, you are stuck with the defaults but they never had the information I wanted all on one screen. I kept having to flick between them which turned into a PITA.
