flak monkey
posted on 22/5/10 at 12:02 PM |
Steel camber adjustersI
I have one set of mild steel camber adjusters available if anyone would like a set?
These replace the aluminium rally design/GTS ones.
Made to standard dimensions, turned section is 63.5mm long and 21.75 diameter.
Thread M18x1.5.
25mm hex
£25 set
I can make more sets if anyone needs some.
Sera
http://www.motosera.com
Yorkie
posted on 22/5/10 at 12:46 PM |
U2U sent.
scutter
posted on 22/5/10 at 08:05 PM |
Flak, How much to make a set with 5mm holes drilled through the end rather than a hex section? i.e. made from round bar instead of hex.
ATB Dan.
