Author: Subject: XFow Misfiring
The Doc
posted on 23/5/10 at 11:36 AM Reply With Quote
XFow Misfiring
Ford Xflow. Runs fine until hot (about 10 mins of driving) Then 'lumpy'. Doesn't appear to be overheating. Not especially smokey
New points (checked setting)
New coil
New condensor
Timing is good
Cleaned out the carb/jets
Any suggestions?
TA
Mike
Q: Who wants to live until they're 80?
A: Someone who's 79
thunderace
posted on 23/5/10 at 11:47 AM Reply With Quote
try new leads?
DRC INDY 7
posted on 23/5/10 at 12:09 PM Reply With Quote
try a set of spark plugs if not new ones
Puddle Dodgers Club
nitram38
posted on 23/5/10 at 12:26 PM Reply With Quote
What coil are you using?
Make sure that you have not used one that requires a ballast resistor after starting the car, otherwise 12v will cook the coil.
You can usually check to see how hot it gets
adithorp
posted on 23/5/10 at 02:48 PM Reply With Quote
From the description check your valve clearences.
adrian
http://jpsc.org.uk/forum/
posted on 23/5/10 at 03:15 PM Reply With Quote
Fuel tank vent ?
posted on 23/5/10 at 06:08 PM Reply With Quote
Check the basics first starting with the valve clearances. Does it miss when at idle or when driving? Found that lagging the exhaust manifold helped with my cross flow engined car, also reduces the underbonnet temperature
fatbaldbloke
posted on 23/5/10 at 07:55 PM Reply With Quote
First thing, invest a couple of quid and change the rotor arm. It's a common fault on the crossflow for the rotor arm to develop microcracks that open with temperature and leak the spark to earth.
The Doc
posted on 23/5/10 at 07:58 PM Reply With Quote
Tried all the above other than the valve clearences.
Happens at high revs and on acceleration and generally not at all until hot. In fact it runs really very well for about 10 mins
I have to say that coil does get hot. Could it simply be too close to the engine?
BTW, have double checked; it's definitely a 12V coil
Mike
A: Someone who's 79
nitram38
posted on 23/5/10 at 09:42 PM Reply With Quote
If you are checking the valve clearances, make sure the rocker arms aren't pitted on the face that meets the valve, otherwise when you insert the feeler gauge you will not get the correct adjustment.
It they are pitted, flaten them off and do the adjustment again
Nash
posted on 23/5/10 at 10:50 PM Reply With Quote
Mike,
What carb are you running? I had a problem with the car going onto 3 pots. It was carb problems. Mine runs a twin choke webber.
........Neil
Build It, Buy It, Drive It:
Southern Kit Car Club
