neo2
posted on 23/5/10 at 08:20 PM |
Any bike engine owners on here for a question
Not sure if its me or my car but ive bought a Factory built GSXR 1000 Mk indy and by christ the clutch sensative,
Let clutch out about inch and half nowt, let it out another 1mm and it bites let iti aout another 1mm and its fully out, im stalling the bloomin thin
9 times out of 10..
Throtle is a bit light and im reving it high when trying to pull away..
Anyone else have any issues like this at all, mine is a cable clutch..
posted on 23/5/10 at 08:23 PM |
Some bike clutches take a lot of getting use to, some are more normal in use. My ST1100 clutch is nice and proportional but I know when I built my car
in the STM garage people taking the blade demo car for a test drive would usually stall it the first 9/10 times...
Jon Ison
posted on 23/5/10 at 08:24 PM |
They do take a bit of getting used to, there designed to be operated with one finger, your using size 9's, you could change the pedal ratio to
make it less sensitive, attach the cable to the pedal nearer the pivot
roadrunner
Bike clutches are like this. I altered mine by changing the pivot point, every little helps.
Oh, and wear thin soled shoes.![](/images//smilies/shocked.gif)
jack_t
posted on 23/5/10 at 08:25 PM |
is it hydraulic or cable
cable is the way forward
mine is loverly and progressive
[Edited on 23/5/10 by jack_t]
skydivepaul
posted on 23/5/10 at 08:26 PM |
yup they are tricky to get off the line.
you could try fitting a different clutch pedal with a less sensitive ratio. i.e refit the cable a bit closer to the pivot point . this will give you
more pedal movement for less clutch engagement.
wish i could type faster!!!!!
[Edited on 23/5/10 by skydivepaul]
http://www.smartideasuk.com
http://www.smartmapping.co.uk
HD CCTV
IP security systems
access control systems
001Ben
yep I had the same problems. I changed my clutch springs for barnett springs which were much stiffer, been fine ever since.
adithorp
posted on 23/5/10 at 08:28 PM |
Ahh. the binary clutch syndrome. It's either on or off and nothing in between.
The answer is to alter the padal ratio by moving the cable attachment point closer to the pivot. That gives a lot more feel but they're still
sharp. It's something you get used to.
Altering the throttle pedal ratio can also help with that but try a return spring on the pedal first.
adrian
http://jpsc.org.uk/forum/
posted on 23/5/10 at 08:37 PM |
Before you go changing the pedal ratio, try adjusting the clutch so it bites a bit sooner rather than the last few mm.
Phil
posted on 23/5/10 at 08:41 PM |
...and just give it some beans as you lift off the clutch.
I always stalled mine.
lococost
posted on 24/5/10 at 07:39 AM |
Had the same problem on my gixxer. Had to go for my first drive without shoes to at least get some feeling. Added a second hole in the gearlever so
the pedalratio would be better. Makes a world of difference, I could wear high heels now and still get away
![](http://www.elitesqd.com/sites/default/files/lococost/images/MK/DSC_0345-1-.jpg)
posted on 24/5/10 at 08:08 AM |
You could just try revving it to 10K then side stepping the clutch. That might work
neo2
posted on 24/5/10 at 07:44 PM |
Some good points there guys thanks seems its the same as all the rest then, ive added two springs to throttle pedal which is now a tough heavy so im
going to try it with just the one on..
Clutch is cable operation so i will give the moving the pivot point idea a go, mines a race car i cant be doing a start and stalling and getting
rammed up the arse with a blooming great M3 or something cause i stalled it....
The only other issue ive got is the Datatool gear indicator went down road in 2nd and it said i was in 6th (i think its been on the drink lol)...
With reguard to the pedal picture above i assume you added your extra hole mod above the original nearer the pivot point yeah ??
Does that little amount make that much difference it looks only about what 5/6mm or so ??
Thanks Rob
lococost
posted on 25/5/10 at 03:29 PM |
Yes.
Yes, makes a big difference, don't know the exact distance, but give it a go, it'll feel much better.
neo2
posted on 25/5/10 at 06:44 PM |
Yeah will have a look at that on thursday when i'm off cheers ![](/images//smilies/smile.gif)
