simonk
posted on 31/5/10 at 09:00 PM |
Good Day in the Garage....
Hello all, not posted for a bit, busy driving the thing......
Had a couple of things lined up to do and got them done this weekend. Firstly got the brake bias adjusted fitted to the balance bar - since SVA the
brakes had gone rear biased (marginally) so took all the locking rubbish off and fitted a proper adjuster and set it up properly.
Also fitted new diff. The old one was the only bit on the car not brand new or properly remanufactured and it had a pronounced metallic knock going
on-off the throttle. Have had new one for a bit on the garage floor but got around to fitting it and it's now a different car. Much smoother to
drive and seems to have improved the gearbox action also.
Also investigated the dreaded bush and crush tube situation as I had to remove the lower offside wishbone to get the diff bolts out - results
interesting and in following post !
Cheers all
Simon
posted on 31/5/10 at 09:04 PM |
All I've managed today is to go in looking for a tape and coming out with a blob of grease on me slippers then leaving it all over the door mat
and living room floor!![](/images//smilies/shocked.gif)
WHEE HAY!
big_wasa
posted on 31/5/10 at 09:19 PM |
I was at work this morning but had a few hours in there this afternoon. Ive made a tray to mount my high presure pump and filter and have mounted it.
I hope to get the fuel system finished this week.
Danozeman
posted on 31/5/10 at 09:24 PM |
I went in my garage this weekend to get a screwdriver and came out again. Havent been back to put the screwdriver away yet either.
Dan
posted on 31/5/10 at 09:33 PM |
I was at work doing paperwork. All day. Happy happy joy joy...
stevebubs
posted on 1/6/10 at 12:17 AM |
I started one car for the first time in 9 months, moved it back, rolled the Fury out into daylight...and called it a day...
jossey
posted on 1/6/10 at 07:56 AM |
i picked up my ready re built zzr 1100 engine.
then welding the steering rack extensions on.
welded up the new suspension coil overs supports at the bottom on the wishbones and new wish bone supports.
then welded on the steering column at a totally wrong angle then moved it.
also sorted the tracking out using a laser pen :O)
so busy one for me.
