HAL 1
| posted on 1/6/10 at 11:04 AM |
2k paint !!
Did a bit of painting on the car this w/end with 2k, unfortunately i got a couple of runs and bits of cr*p on the surface,
so after rubbing down i'd like to know if there's any minimum length of time before i can respray it ?
i'm asking this cos i know that it might be dry but will it need to be cured before more paint goes on ?
or shall i bin the idea and go back to celly ?
BTW, used all the right stuff, air fed, full suit etc
jossey
| posted on 1/6/10 at 11:09 AM |
tape up the floor and walls with dust sheet celephane to stop dust.
if the weather has been ok you can sand and clean up then spray within a few hours.
i use a heat lamp to dry it off quicker.
but i have massive issues with dust living near farms and having a gravel drive.
so i built a plastic dust sheet enclosure.
works well.
HAL 1
| posted on 1/6/10 at 12:44 PM |
Cheers for quick reply jossey, you've put my mind at ease there, i'll be getting on with it at the w/end
I think some of the cr*p was due to me not cleaning the gun properly
ta
jossey
| posted on 1/6/10 at 01:03 PM |
if you have a oil rad put that on when your done with the paint. will help it dry a little quicker and less risk of dust etc.
good luck.
glad i could help.
i have been doing that last few weeks so i know its a pain.
Irony
| posted on 1/6/10 at 01:38 PM |
My 2k paint is a pain to dry. I have found with experimentation that if the part is small enough bung it in the oven on the ovens lowest setting. Or
as suggested above using a radiator below the part.
austin man
| posted on 1/6/10 at 05:57 PM |
The crap may have been in the paint I use old tights to strain the paint into the pot, Wet the floor to stap dust rising if painting a small area
gently heat with a hot air gun
