spiderman01980
posted on 2/6/10 at 09:12 PM |
HELP!!! from a bike carb expert!!!
what are theese holes circle in red?
i seem to have petrol flowing out of them!
what is there job what are they there for?
prawnabie
posted on 2/6/10 at 09:18 PM |
Look like air correction holes, have you got the fuel pipes plumbed up right?
trikerneil
posted on 2/6/10 at 09:25 PM |
Possibly floats stuck or float heights set incorrectly.
Neil
ACE Cafe - Just say No.
Dingz
posted on 2/6/10 at 10:05 PM |
What fuel pump are you using?
went on and on.
trikerneil
posted on 3/6/10 at 05:10 AM |
Good point Dingz, those carbs are probably designed to be gravity fed.
Neil
posted on 3/6/10 at 06:25 AM |
If this is the first time you've connected these carbs - I'd suspect that you're putting fuel into the wrong pipes, maybe the ones
that vent the top of the float chamber...
...but otherwise - sticky float valves or too high a fuel pressure, as stated above.
Surrey Dave
posted on 3/6/10 at 07:45 AM |
Pressure?
Probably floats stuck or too much fuel pressure you only need about 1 - 1.5 lbs on bike carbs, a lot of people use a bike pump which automatically
cuts off , or you can use a filter king fuel regulator but it has to be set very low, an accurate way of measuring the pressure is with a clear
vertical tube 28" per pound of pressure? can't remember off hand......
tony-devon
posted on 3/6/10 at 07:50 AM |
if its all of them that are leaking out, then its a bit unlikely to be the float needles
sounds like excess fuel pressure
them carbs are normally gravity fed
either lower the pressure on the fuel pump
or
I once put a small tank above the carb height, then fed the pump to this with a return from the top to the main tank.
was my simple dodge/cure
heavy is good, heavy is reliable, and if it breaks, hit them with it
NigeEss
posted on 3/6/10 at 08:28 AM |
Sounds like a neat alternative to a swirl pot too
tony-devon
posted on 3/6/10 at 10:14 AM |
it was a method that I used on a custom bike
the fuel tank was hidden/integral with the frame, but with a tiny tank in the top tube of the frame to provide the gravity feed for the carbs
the fuel was fed at its own pace, the system worked very well
r1_pete
posted on 3/6/10 at 11:08 AM |
1st question as has been asked, where have you connected the fuel, should be into that plastic T, with the pipes feeding 1&2 and 3&4.
The other pipes on show are water heaters and can be discarded, from memory there are two more higher up the carbs which are vents.
spiderman01980
posted on 3/6/10 at 07:20 PM |
a Facet fuel pump which i think it pumps bout 4 to 7 psi! i have been advised to put a regulator on it, but it was doing that when i put a little tank
above it with out the pump!
spiderman01980
posted on 3/6/10 at 07:24 PM |
yeah its connected to the T!
posted on 3/6/10 at 09:25 PM |
Far, far too high a pressure - a bike pump gives about 1.5psi but with a high volume. I know that you've tried a gravity feed, but you'll
have to sort the pump out regardless of whatever's causing this issue.
FASTdan
posted on 4/6/10 at 07:16 AM |
Our facet redtop works well with the ZX9R's using a filterking style regulator to turn the pressure down to 1.5psi.
