Irony
posted on 9/6/10 at 11:05 AM |
Guide to head porting
I am rebuilding a Rover V8. I have been reading my book 'How to powertune a Rover V8' and it mentions polishing/cleaning up the inlet and
exhaust ports in the heads. I have my heads off now and they are in general good condition. A good clean to get some grott off and they will be okay
I think. Whilst I have them off is it worth me doing some grinding polishing work on the ports?? I am a dab hand at using a dremel but I need some
instruction as I am a newbie.
Is it worth me doing this? If so is there a half decent guide anywhere?
dan_g8
posted on 9/6/10 at 11:31 AM |
hi, im not going to be any help with your question. but im planning on rebuilding my v8 soon, where did you get your book from ? i had a look on
amazon and its over £150 !!!
ta dan
Jon Ison
posted on 9/6/10 at 11:50 AM |
Don't know the heads in question intimately but a few general tips.
Do not highly polish the ports.
Highly polished and all sharp edges removed from combustion chambers is the way to go.
Remove any casting flashing.
Smooth radius's are what to go for.
Air does not like tight turns.
The valves/stems/guides are a big restriction, any widening in this area will be a plus.
Ports can be to big !!
Match the port joints to the manifolds, when assembling make sure the gasket does not stick into the port to restrict flow.
Dan, I have vizards RV8 book at home, want it ?
Rod Ends
posted on 9/6/10 at 12:03 PM |
Porting School articles by David Vizard
Irony
posted on 9/6/10 at 12:11 PM |
ta dan
ebay i think. A good website is Mez. Can't remember the addy but just google Mez Rover V8
contaminated
posted on 9/6/10 at 12:51 PM |
I've got a PDF'd porting guide. Send me your email.
Dan
Tiger Super Six Independent
www.southernkitcars.com
contaminated
posted on 9/6/10 at 12:53 PM |
Interesting, I'd half agree with that. I'd highly polish the exhaust ports but leave the inlet ports rough to encourage air turbulance.
Any views - I'm about to have a go myself.
mcerd1
posted on 9/6/10 at 01:19 PM |
quote: Originally posted by contaminated
I'd highly polish the exhaust ports but leave the inlet ports rough to encourage air turbulance. Any views - I'm about to have a go
myself.
I've been told about not over polishing the inlet ports by several different engine builders that I'd trust
but I'm not sure if you'd gain anything noticable by polishing the exhaust ports to a mirror finish....
only one way to find out I suppose - it'd be interesting to see if you can measure any difference
posted on 9/6/10 at 04:11 PM |
Commonly held belief is that you want a slightly rough inlet to ensure turbulent flow to keep the air / fuel mixture mixed and to ensure a good
boundary effect. Some people though say that the fuel / air mix moves too quickly for this to be an issue, however, dynos seem to suggest that a
slightly rough inlet is a good thing.
