Author: Subject: Ford Coil Pack and Spark Plug leads - Pinto
karlak
posted on 10/6/10 at 08:28 AM Reply With Quote
As the title really.
Changing to Megajolt on the Pinto and understand that I will need different Plug leads to connect to the Ford Coil Pack. Does anyone know what type I will need ?
MK Indy - 2litre Duratec - Omex 600 - Jenvey throttle bodies - ETB DigiDash2
r1_pete
posted on 10/6/10 at 09:05 AM Reply With Quote
Depends on the age of the coil pack, early ones to about 1999 had clip on leads, later ones were a more conventional push in, not sure whether conventional dizzy leads fit though.
You can tell the early coils, they have a lip around the rim for the clips to grip.
[Edited on 10/6/10 by r1_pete]
posted on 10/6/10 at 09:08 AM Reply With Quote
Do the standard coil pack leads not fit the pinto plugs?
Dave Colledge at Retro Ford is the man who knows...
smac
posted on 10/6/10 at 09:23 AM Reply With Quote
I have some at home, ill have a look at the box tonight and tell you what they are originally from.
Simon
mcerd1
posted on 10/6/10 at 09:51 AM Reply With Quote
if you've got an early style coil pack (see pic) then a 1.3 /1.6 escort / fiesta circa 92-94 should do the trick - I think there are a couple of lenghts you can get depending on the exact model (best to go into your local motorfactors and have a look in there cataloge for a min)
or anything else that had the same coil pack with an old fashoned 8v engine
if you've got the later style coil pack then its KA one I think.....
the 16v engines have leads with those big rubber boots that fit into the head - so not much use to you
[Edited on 10/6/2010 by mcerd1]
pajsh
posted on 10/6/10 at 11:12 AM Reply With Quote
I bought some adaptors from Halfrauds that convert the plain ends of a dizzy lead to the clip required for the coilpack above.
Never had any problems.
Just visible here
Pinto 2.0 - 2
Pinto 2.0 - 2
[Edited on 10/6/10 by pajsh]
I used to be apathetic but now I just don't care.
smac
posted on 10/6/10 at 05:41 PM Reply With Quote
Right had a look at the box but no vehicle details. They are from Sovereign and marked SL070. They are for the older larger coil pack (as pictured above)
[Edited on 10/6/10 by smac]
mcerd1
posted on 11/6/10 at 02:21 PM Reply With Quote
looked out the box from mine, its an ElectroSpark 'OEK047' kit
but I've just found there cataloge which does cross-reference searching: linky
the Sovereign SL70 = a prospark OES112 apparently
and mine are the same as an SL50... linky 2
I think the only difference between the 2 different links is the lengths - but it doesn't tell you what they are
[Edited on 11/6/2010 by mcerd1]
