dan_g8
posted on 11/6/10 at 12:30 PM |
Rover v8 - injection or carbed?
Hi, i currently have a a rover v8 which is injected. in a coupole of months (when funds become avaliable) i plan on rebuilding the engine.
What are peoples opinions? do i stick with the injection or should i sell the injection and change to carbs?
if i go to carbs it will also help with my clearance problems between engine and bonnet.
thanks
![](/galpreviews/a1162447-eng1.jpg) ![Rescued attachment eng1.jpg](/gallery/a1162447-eng1.jpg) Rescued attachment eng1.jpg
marcjagman
posted on 11/6/10 at 12:55 PM |
I prefer carbs, they look so much niver and not as many wires and stuff in the way. Most prefer injection as it can be tuned better and is generally
trouble free and more economical.
deezee
posted on 11/6/10 at 01:01 PM |
Can you get away with carbs with regards to the IVA emissions test?
AdamR
posted on 11/6/10 at 01:07 PM |
Injection is generally the better option, even using antiquated flapper systems as used on early injection RV8s.
You can partially address the bonnet clearance issues by machining around 30mm off the trumpet base. I've just had this done... will post of
some pictures when I get a chance. Hopefully won't need a bonnet bulge now at all.
[Edited on 11/6/10 by AdamR]
turbodisplay
posted on 11/6/10 at 01:13 PM |
To me injection is simple, carbs are (more)difficult. To most people it is the other way round. As it is a V8 it will use more fuel so fuel injection
is the only thing that makes sesnse on a 2l+ engine.
The injection system should be simple to setup, either megasquirt or use orriginal setup.
Darren
Irony
posted on 11/6/10 at 01:23 PM |
I have just been through the whole should I carb or inject my RV8 question. In the end I plumped for the carb option as I don't know anything
about EFI and I am new to car building. I also got one at a good price from a fellow locoster.
From all the research I did however I would suggest that EFI is the better option but more difficult to install if you are not familiar with it.
This whole topic is a huge can of worms through with everyone having there own opinion. One bloke even claimed that carbs sound better. I
don't know if its true.
Head here for some good advice V8forum
Rinky Dink Link
scudderfish
posted on 11/6/10 at 01:30 PM |
I've just gone from carbs to MS EDIS on my RV8.
I was never happy with carbs as they struck me as not far removed from voodoo. My car ran fine, but I did have issues with my dizzy/coil/ignition amp
set up.
I now have a redundant RV8 manifold with a Weber 38DGAS sat on top if you're interested. Random pictures of it here
http://picasaweb.google.com/dave.g.smith/ManifoldSwap#
scudderfish
posted on 11/6/10 at 01:34 PM |
Another thought, this page
http://www.spagweb.com/v8mini/gallery/05/01_efi_compare/
has a good size comparison of various EFI options. The EFI set up I have is the smallest on that page, so that will give you an idea of how big the
DGAS is.
Paul (Notts)
posted on 11/6/10 at 03:01 PM |
The simplest option is Carbs
Then carbs + megajolt ( gets rid of Dizzy)
Then the next option is standard injection + ecu
then megasquirt
Then custom injection using Bike throttle bodies
(just for show)
I hahe done the first two and now changing to a semi standard injection (thor system) on Megasquirt then adding bike throttle bodies for show.
Paul
The only reason I keep changing is I like to try it.
richardh
posted on 11/6/10 at 03:30 PM |
INHO CARBS every time
Time for a change!
RAYLEE29
posted on 11/6/10 at 07:44 PM |
hi, my rv8 with a holley (in a tr7v8) drinks fuel id go injection especially as you already have it.
single plenum should be good for 200 horses and should be alot smoother.
by the way rv8s are money pits to rebuild does it really need rebuilding?
Ray![](/images//smilies/smile.gif)
dan_g8
posted on 11/6/10 at 09:00 PM |
Thanks for the replys everyone, looks like ill stick with the injection.
Ray
To be honest i dont think that it will need a full refurb. The person i bought it from "said" that he had never had issues from it.
But when i removed the oil filter the oil was extreamly thick and black so im guessing that the oil hadn't been changed for a while.
I was thinking about a small rebuild. Gaskets, Degrease & painting the block, maybe new piston rings, big end bearings & a hone.
Can you think of any thing i should do/ not do?
Dan
robinj66
posted on 11/6/10 at 09:58 PM |
If the engine has a high mileage (quite possible if the oil is black sludge) then think about changing the cam and the follower, new timing chain and
sprockets, lapping the valves in (at the very least).
Check the oil pump housing for signs of wear/ possibly replace the oil pump gears.
Trouble is, where to end? depends on what state of tune you want to push your engine to.
