Author: Subject: Honda Fireblade throttle bodies
j37w
posted on 13/6/10 at 07:46 PM Reply With Quote
Has anybody used these on a Zetec? Could do with knowing if the TP sensor was ok, if one vacuum pipe off each body is ok for the MAP sensor, if it is best to block off the other air feeds - and any other tips would be greatly appreciated. I have them on an ST170 manifold and will be using an Omex 600. John
austin man
posted on 13/6/10 at 07:52 PM Reply With Quote
Brother in law has blackbird carbs on his 2 litre zetec and uses the TPS he is using the emerald ECU and has no problems. The TPS is only a potentiometer which give the ecu a realtive position for throttle opening
madteg
posted on 13/6/10 at 07:58 PM Reply With Quote
I do works fine for me
