<<  1    2  >>
Author: Subject: Splitters and Canards
mangogrooveworkshop
posted on 14/6/10 at 01:04 PM Reply With Quote
Whats the general opinion on the the effectiveness the use of on a seven.
Want to design and make some for the bec
posted on 14/6/10 at 01:12 PM Reply With Quote
About as much use as a nuclear-powered intercontinental ballistic haddock.
It's Evolution Baby!
posted on 14/6/10 at 01:14 PM Reply With Quote
... IMHO of course!
smart51
posted on 14/6/10 at 01:34 PM Reply With Quote
cycle wings produce a lot of lift. A little spoiler at the rear of the wing can reduce the lift. I guess a cannard would too. It might even stop your wing stays from breaking.
A splitter stops air the front of the car going underneath. Given the big hole in the front of the nose cone and the open floor, I'm not sure a splitter would do much. A deeper squarer "chin" like a donkevoort or a newer MNR might be more effective.
You might also want to consider panels on your wishbones if you want to reduce front end lift. Angled upwards, they might add a bit of down force to your suspension.
Generally, aerodynamic aids work better on the front of a seven than the rear. That is because the shape of a seven churns up the air so much there's not a lot you can do with it at the back. Front end aero aids should work fairly well though.
richardlee237
posted on 14/6/10 at 02:00 PM Reply With Quote
They're canard to make !!!
Quote Lord Kelvin
“Large increases in cost with questionable increases in performance can be tolerated only in race horses and women.”
Quote Richard Lee
"and cars"
eddie99
posted on 14/6/10 at 02:06 PM Reply With Quote
I have got hold of some carbon canards, just to push a bit of air over the wishbones to make it a tiny bit more aerodynamic. Caterham have them so they much do something All little helps
http://www.elitemotorsporteng.co.uk/
Twitter: @Elitemotoreng
Facebook: http://www.facebook.com/pages/Elite-Motorsport-Engineering/153409081394323
Bluemoon
posted on 14/6/10 at 02:31 PM Reply With Quote
Originally posted by eddie99
... Caterham have them so they much do something All little helps
empty your pockets??
Not convinced by any aerodynamic aids on a 7, if you want aerodynamics you'll end up with a completely different car
As far as I can make out any aerodynamic effects tend to happen at higher speeds >80mph so you generally don't get any benefit (maybe on track??)..
Dan
sucksqueezebangblow
posted on 14/6/10 at 02:36 PM Reply With Quote
I have fitted a full undertray and have ordered the carbon sandwich to make my splitter. I suppose to be fully effective it would have to strech back to the back of the bonnet line to split all the air going under the car, but I reckon doing the nosecone should be adequate. Bear in mind also that with a full undertray you will need venting in the bonnet or sides of the engine bay.
I'm not sure how effective cannards will be but they will probably add a little downforce (and drag). I'm also planning to fit Gurney flaps on the back curve of the front and rear arches to break the airflow away and reduce lift.
Alan M
posted on 14/6/10 at 02:37 PM Reply With Quote
I agree. Aerodynamic aids do nothing at speeds below 70mph. So unless you have warp drive, don't bother!
Richard Quinn
posted on 14/6/10 at 02:43 PM Reply With Quote
... and didn't the Emperor have some new clothes once?
Jumpy Guy
posted on 14/6/10 at 02:51 PM Reply With Quote
Hey, if they look good, and dont weigh too much, then what harm can they do?
A little bit of bling doesnt do any harm....
CNHSS1
posted on 14/6/10 at 02:55 PM Reply With Quote
imho aero additions such as canards and to a certain extent, splitters, are trimming devices to balance the downforce F&R. in the case of a 7Type, you only get inherent lift, so pretty pointless, again imho. panneling the underside will reduce lift, especially at the rear axle area, where most 7 types bodywork act as a kite!!
The nose is akin to a tescos bag in the wind, great for trapping air but not much else. the inlet duct for the rad must be well sealed and an escape route for the hot gasses found (bonnet vents, NACAs or ally chassis side panels that are open at the trailing edge. Panelling in the underside of the engine bay often improves engine cooling as the flow through the radiator isnt stalled on its exit by random airflow cascading from underneath the car and buggering up the flow of hot air from the rad.
I think reducing and at best negating lift, is your best goal, real DF without figure hugging full arches, cowlings for the exh system and proper aero bodywork isnt gonna work. There were a number fo race and hillclimb westies that had aero enveloping bodywork (Black Brick rings a bell), but they dont end up looking like a 7 type.
although a 7type is drag city (kiddies climbing frames have a high drag factor) , its not all bad news. If you can reduce say 50kgs of lift at 100mph to 10kg lift, you have a net gain of 40kgs of 'nearly downforce' so that will make the car much more stable at speed.
from what ive done on my hilllclimber, small gains (in lift reduction) are much more confidence inspiring, so worth the effort
[Edited on 14/6/10 by CNHSS1]
T66
posted on 14/6/10 at 03:28 PM Reply With Quote
I see your back then.....lol
SeanStone
posted on 14/6/10 at 03:34 PM Reply With Quote
There's no real reason why a real splitter couldn't work on a 7 car. You need a flat surface where the air stalls then you need a lip for that high pressure air can be used for downforce. So it'll work but it will need to be well supported. I can't really see it having much use for the normal zetecs/bec/pintos whose top speeds are quite low. Probably better for those achieving 120-130+ where the front really starts to wander
Humbug
posted on 14/6/10 at 04:19 PM Reply With Quote
Re cycle wings... I like the look of the ones (Caterham CSR? MNR?) which have vents at the back and maybe they really do let out some of the air build up and reduce lift.
To reduce cost - and a tiny bit of weight - coud you just carefully mark up 3 or 4 lines on the relevant place on the back of the wing and use an angry grinder (carefully" to cut some slits? Would that work, or would you get rain sloshing out of the slits in rain?
Alternatively, some ali louvre vents from B&Q could work, probably best if painted to match the wings though.
Opinions on a postcard
mangogrooveworkshop
posted on 14/6/10 at 05:31 PM Reply With Quote
Its at 70 that we start lifting
Lower speeds I dont care what its doing just want the nose to stay put at the higher cruising speeds.
Cost to me is almost zero its just the time that it will cost me.
I had thought of the panels in the bones...
Ive also got most of the materials to make it.
So if anyone has ideas please tell me
posted on 14/6/10 at 05:39 PM Reply With Quote
Indeed... you're Rad is in the post!
Bluemoon
posted on 14/6/10 at 06:08 PM Reply With Quote
Are you sure it's aerodynamics and not something else in the setup?? My indy is not the best at speed at the moment, main problem is bump-steer that I have yet to dial out and possibly the old caster problem, makes things feel a little light up front at 70mph.
Dan
flak monkey
posted on 14/6/10 at 06:12 PM Reply With Quote
I have just fitted Canards to mine, not driven it yet - but I will report back on the findings!
Caterham had positive results in the wind tunnel by fitting them.
They were more designed to channel air over the front suspension than increase downforce from what I understand.
That said mine doesnt start to go light at the front end until well over 100mph....
Sera
http://www.motosera.com
fha772
posted on 14/6/10 at 06:13 PM Reply With Quote
What is the aerodynamic advantage of fixing French ducks to your car?
Or, have i mis-understood, again?
http://www.ppcmag.co.uk/forum/viewtopic.php?f=47&t=6743&start=105
iank
posted on 14/6/10 at 06:34 PM Reply With Quote
I almost made the same joke, but I felt it was a lame duck... I'm here all week, try the veal!!
Anonymous
PAUL FISHER
posted on 14/6/10 at 06:58 PM Reply With Quote
I had some of the carbon mods canards on my old Indy R ,I can't say they made any difference,but they did look nice
mcerd1
posted on 14/6/10 at 07:05 PM Reply With Quote
what about 'longer' front wings that cover more of the front of the wheel ?(and stop as much getting undernees them)
mcerd1
posted on 14/6/10 at 07:08 PM Reply With Quote
I need one of those - I own a cat in Russia with a a lead lined stomach that I'd like to be able to feed it without leaving the house
T66
posted on 14/6/10 at 07:31 PM Reply With Quote
Blatant twoc of thread, thanks Scott...
<<  1    2  >>
