Author: Subject: What size Fuse for Electric Reverse ?
Tris
posted on 15/6/10 at 06:36 PM Reply With Quote
Hi All,
Quick question - what size fuse should i use for an electric reverse ? (motorbike starter onto the diff type)
Tris
posted on 15/6/10 at 06:48 PM Reply With Quote
Get a selction of mega fuses say 100 to 150 amps put a low one in first. and see what happens.
Davegtst
posted on 15/6/10 at 06:50 PM Reply With Quote
Get hold of an amp clamp and try it under load.
Tris
posted on 15/6/10 at 07:03 PM Reply With Quote
The car is currently on stands at the mo, so its difficult to get an idea under load. It sounds like i need to aim for a maxi-type of fuse, so will get a couple to try
Tris
Mark G
posted on 15/6/10 at 08:19 PM Reply With Quote
To do it any better than a guess you'd need to know the motor specs. More info would be required before being able to work it out.
zetec mike
posted on 15/6/10 at 11:16 PM Reply With Quote
I would guess in the region of 150 amps. dont think maxi come bigger than 80. Partco stock some 150 and i think bigger for the RAC jump start jacks on the vans.
posted on 16/6/10 at 07:19 AM Reply With Quote
I have a fusible link here off a Nissan Note.
It bolts direct onto the battery terminal and has a main 250a then 4 80a fuses for the main harness. Starter cable bolts to the top.
I can bring to Newark a couple for you to play with. Here's the drawing... Rescued attachment Fuseable Link.jpg
40inches
posted on 16/6/10 at 08:28 AM Reply With Quote
Mega Fuses and holders from here up to 250amps continuous
