rich201283
posted on 18/6/10 at 07:31 AM |
Antibloom thinners or standard?
I am going to spray another coat of celluose after flatting back, I have been using standard thinners, should i be useing antibloom thinners? I thort
antibloom is only for colder weather
austin man
posted on 18/6/10 at 07:32 AM |
use standard unless your going to paint when there is a bit of dampnes in the air humid, later on in the evening etc or cold. Use a quality thinner
though
r1_pete
posted on 18/6/10 at 08:29 AM |
You should use a slower 'drying' thinners for topcoat, this allows time for the paint to flow when on the surcface, and the varnish in the
paint to rise to the surface.
Your paint factor should be able to advise, but if you ask for top gloss thinner you'll get the right stuff.
skinned knuckles
posted on 18/6/10 at 09:28 AM |
+1
A man isn't complete until he's married, then he's finished
