Author: Subject: Can anyone help me to identify this cam?
fathead
posted on 18/6/10 at 12:12 PM Reply With Quote
I have recently bought a 2.0 pinto and the Cam is stamped on the end with "Z10786". My understanding was that if it was a stock cam then it would not have a stamp on the end. I have googled it and one result says its a Kent RC1 and the other says it's stock.
Any ideas?
Thanks in advance
turbodisplay
posted on 18/6/10 at 12:18 PM Reply With Quote
Measure a lobe, highest point, lowest point, and calculate the difference.
If it has a higher opening than stock, then it is atfer market.
Darren
austin man
posted on 18/6/10 at 12:21 PM Reply With Quote
it doesnt show up on Kent Cams website
snapper
posted on 18/6/10 at 04:34 PM Reply With Quote
From a thread on the turbosports forum you can set the cam by setting No.1 piston to TDC , run a bar across both inlet and exhaust lobes, level both ends ofthebar to the rocker cover face either side.
This will time the cam, do up the vernier then find where the inlet is fully open, you can then find, cam timing, duration and lift .
All the info you need
I eat to survive
I drink to forget
fathead
posted on 19/6/10 at 06:12 AM Reply With Quote
Thanks for your help gents.
