phelpsa
posted on 18/6/10 at 07:03 PM |
Rolling roaded...
We had the Locost rolling roaded and setup at Big CC this week.
After a day of carb fiddling and 6 runs on the rolling road it made 121bhp at the wheels and pulls beautifully all the way through the rev range
not bad for a 20 year old engine.
Any ideas what 121bhp is likely to equate to at the crank?
phelpsa
posted on 18/6/10 at 07:11 PM |
I dont know how this ended up in the for sale section.... i'm not really with it tonight! Any chance it can be moved to the BEC section?
flak monkey
posted on 18/6/10 at 07:37 PM |
Add 17-20% for flywheel figure So anbout 145bhp at fly.
Sera
http://www.motosera.com
phelpsa
posted on 18/6/10 at 07:38 PM |
Well it came from the factory with 143bhp so i'm happy with that!
matt_gsxr
posted on 18/6/10 at 10:05 PM |
Nice one Adam, so you (actually your dad) fixed the fuel leak.
Those figures sounds very credible and should be very lively in your lightweight car.
Have you a printout of the torque curve? mine has a serious torque peak at 7k (reving out to 11k) which makes it very strong on the road, although a
bit surprising as you accelerate in 2nd but lose traction when as you hit the torque peak.
I haven't rolling roaded (I am too mean, and my car has too many weird mods to bother explaining but I'd like to sort the ignition timing)
but am now using 95% of the fuel injector capacity at 12.8AFR (and I believe these injectors are the same as Hayabusa injectors) so I too am a
believer in these old Gixer engines.
Nice work,
Matt
phelpsa
posted on 19/6/10 at 08:58 AM |
The carbs still spurt fuel every now and again, pretty sure its just too much pressure as they hooked up a gravity fed tank on the rollers and it was
perfect. Going to splash out on an adjustable pressure regulator to try and improve things.
They're going to email us the curve as the printer wasnt working on the day. Apparently it wasnt worth revving past 10k and it was pulling
really hard at 7-8k.
It brought up a list of things to look at though so it's going to be a busy few weeks between now and the airfield day!
matt_gsxr
posted on 20/6/10 at 10:29 PM |
Yeah, big torque peak at 7k
Here's my VE (EFI fueling) table, which shows the same characteristic.
  ve_table_gsxr1100_1000TBs
All GSXR1100 have the characteristic peak at 5k, then a dip, and then a second peak at 7k.
random gsxr1100 torque curves
Matt
phelpsa
posted on 20/6/10 at 11:37 PM |
Well it'll be interesting to see the torque curve when they send it through to compare it. They seemed to think it was as expected and there
were no real problems once the dynojet kit was fitted.
Will post them up when I get them
ZEN
posted on 21/6/10 at 10:44 AM |
Is that the air/oil cooled engine?
My YouTube channel Cars, bikes - track days, motorsport, sim racing and more.
phelpsa
posted on 21/6/10 at 12:07 PM |
Mine is, Matt's is the watercooled version
matt_gsxr
posted on 21/6/10 at 01:25 PM |
The previous link had torque curves for both, and they are pretty similar.
In actual fact the WP (water cooled version) is only incrementally different to the old oil/air versions. It retains the cooling fins (for example),
and doesn't seem to mind too much when you run out of water (as I did when my water pump developed a massive leak).
Matt
ZEN
posted on 21/6/10 at 01:30 PM |
Interesting! I presumed that air/oil cooled bike engines where not suitable for a BEC.
Is your car for racing only?
How heavy is the engine?
phelpsa
posted on 21/6/10 at 04:11 PM |
They aren't really air cooled at all in the last models, they have a twin oil system (google SACS) which means you dont really need much airflow
at all, just a massive oil cooler!
It is for racing only but i know of a few people who have installed GSXR and Bandit engines in road cars
The engine's not as light as modern bike engines, probably around the 75kg mark all in.
[Edited on 21-6-10 by phelpsa]
ZEN
posted on 21/6/10 at 04:33 PM |
I already knew about SACS. That is why I wrote air/oil cooled.
I just thought that there is a grater need for fresh airflow. Got any photos of your oil cooler installed?
phelpsa
posted on 21/6/10 at 05:11 PM |
My point is more that they don't really require any more airflow than a watercooled bike engine, especially if you fit an oversized oil cooler,
because the SACS system is so effective. The last GSXR models were entirely faired so they weren't getting much air to the engine at all.
Mocal oil cooler (about twice the capacity of the standard gixxer one):
Also has a fan on it.
It keeps it at a temperature of 72-73degC when sat idling and on 6 rolling road runs only reached a maximum of 79degC.
ZEN
posted on 21/6/10 at 05:17 PM |
How much oil does it take?
phelpsa
posted on 21/6/10 at 05:28 PM |
The oil cooler? About 3/4 of a litre more than the standard one, as thats how much extra I had to put in to get it to the max level Its the same
surface area but twice as thick and with finer cooling fins.
