Author: Subject: switch point voltage for lc1
mr zefect
posted on 23/6/10 at 09:30 PM Reply With Quote
Can anyone tell me what the ego switch point voltage should be for a lc1 senser mine is set at 2.352 is this correct.
flak monkey
posted on 23/6/10 at 09:32 PM Reply With Quote
Depends how you have it configured, also if you are running target tables the switchpoint figure is ignored anyway.
If you arent running target tables but still closed loop (bad idea IMO) then you just set it at whatever voltage gives you 14.7 afr.
Sera
http://www.motosera.com
mr zefect
posted on 24/6/10 at 10:31 PM Reply With Quote
Thanks.
