Author: Subject: prepping alli for paint
Jumpy Guy
posted on 28/6/10 at 02:34 PM Reply With Quote
I have some upol etch primer for the alli bodywork. My question is -
It hasnt been polished since i built it, so its clean, but has some surface oxidation, and its dull
Can i etch primer onto this? or do i have to clean it to a shine first?
how do i get rid of the peek! residue, i assume i cant primer straight on top?
cliftyhanger
posted on 28/6/10 at 02:42 PM Reply With Quote
not an expert on ali panels at all, but no reason I can see why it can't be prepped using 600 grade wet and dry. Then wash, panelwipe and etch prime. Then a couple of high build primer coats, flat with 800 and then topcoat. So just like I would treat steel....
ashg
posted on 28/6/10 at 03:13 PM Reply With Quote
just use a green scotch pad to cut the surface. It will remove the oxidation and key the panel for primer at the same time
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
posted on 28/6/10 at 03:16 PM Reply With Quote
It would probably happily etch through the oxide layer but a quick 20 second scuff with some W+D seems a quick nod in the direction of "prep"
deltron63
posted on 28/6/10 at 06:18 PM Reply With Quote
make sure you dont touch the ali with your hands after you've panel wiped it.
it sounds silly but the acid in your hands can leave marks that will show up after it's painted
vinnievector
posted on 29/6/10 at 09:28 PM Reply With Quote
As said scotch bright and soap water rinse off leather down ready to go .
