Author: Subject: How Safe Would You Feel...
posted on 5/7/10 at 08:10 PM Reply With Quote
... with this tank underneath your seat? Assuming of course it is suitably strapped!
PRODUCT DESCRIPTION
This new 8 gallon Pro Mod Fuel Cell measures 14"x17" and is 10-1/4" tall at the rear. Its unique shape is well suited to fron mount applications. This fuel cell comes standard with two AN-12 Fast Flow outlet fittings, one AN-8 Tip Over Valve vent, and two AN-8 return lines with an Anti-Aeration Tube attached. It also features an aircraft style cap assembly and is SFI 28.1 certified.
It's Evolution Baby!
adithorp
posted on 5/7/10 at 08:15 PM Reply With Quote
Not very... 'cos to get it under the seat my head would be 12" above the roll bar.
adrian
http://jpsc.org.uk/forum/
dinosaurjuice
posted on 5/7/10 at 08:16 PM Reply With Quote
no problem. so long as its filled with mans fuel. diesel.
iank
posted on 5/7/10 at 08:30 PM Reply With Quote
So long as there was a sealed bulkhead between cheeks and plastic and OEM spec hoses used I'd be happy.
Motorbikes have their tanks next to your lungs and people don't seem worried.
Look at it like this, if it split due to being rammed you'd be unlikely to burn to death.
Anonymous
l0rd
posted on 5/7/10 at 08:31 PM Reply With Quote
Would be a nice footrest instead of sitting over it.
scudderfish
posted on 5/7/10 at 08:34 PM Reply With Quote
adrian
Looking at your avatar, it already is!
posted on 5/7/10 at 08:36 PM Reply With Quote
I was also thinking that if a collision caused it to split, then fire would be the least of my worries Ian!
Only thing is, the design in my head doesn't have a sealed bulkhead between cheeks and tank!
Single seater, so solid bulkhead between engine bay and tank / cockpit, but the seat will just bridge the space over the tank.
tomgregory2000
posted on 5/7/10 at 08:38 PM Reply With Quote
And a nice hot engine below that
andyw7de
posted on 5/7/10 at 09:02 PM Reply With Quote
Scott,
Is that not a similar set up to what the FVL has??
Im sure the "Bag tank" only has a thin bit of ali between your cheeks and the tank unless you were posh and actually had a seat
just dont hit anything
minitici
posted on 5/7/10 at 09:03 PM Reply With Quote
My single seaters have all had wedged shaped fuel tanks directly behind the seat.
They did also have a sloping aluminium bulkhead which was sealed.
The resulting compartment between the engine fire wall and the sloping bulkhead had suitable drainage holes to let out any spilt fuel.
The filler pipe was routed out the side of the compartment.
IMHO - This is the safest place for the tank as it has the most protection from impacts - I have destructively tested this
[Edited on 5/7/10 by minitici]
andyw7de
posted on 5/7/10 at 09:06 PM Reply With Quote
I haven't
yet
Speed is just a question of money !
How fast do you want to go ?
mark chandler
posted on 5/7/10 at 09:07 PM Reply With Quote
Series I landrovers, you lifted the seats to fill them up, and they had leaky fillers.... would not worry me.
minitici
posted on 5/7/10 at 09:14 PM Reply With Quote
I used to get some very funny looks when I went to fill up my Series I .......
welderman
posted on 5/7/10 at 09:39 PM Reply With Quote
thats where mines going to have to go so no problemo for me mate, will u2u tomorrow too
Joe
craig1410
posted on 5/7/10 at 10:02 PM Reply With Quote
I have driven go-karts at over 100MPH with the fuel tank between my legs so this wouldn't bother me too much....
Canada EH!
posted on 5/7/10 at 10:08 PM Reply With Quote
Looks like a fuel tank for a rail dragster, usually mounted at the front of the vehicle just behind the front axle.
posted on 6/7/10 at 08:09 AM Reply With Quote
indeed, series land rover lightwieghts had one 10 gallon tank under each seat, top filler, caused no problems.
motorcycle_mayhem
posted on 6/7/10 at 09:35 AM Reply With Quote
My Jedi has a 15 litre tank that forms the seat back, isolated by a thin sheet of Ali., with the exhaust downpipes the other side of that.
Does it bother me? no.
My Jedi also has the front axle line and steering rack behind my ankles, not in front.
The Nanny State is slowly removing my ability to make such decisions over my safety.
Does that bother me? yes.
Living is dangerous, don't do it.
OK - I think a JAZZ (or similar) is a fantasticly safe way of storing fuel, anywhere on the car. Go for it.
posted on 6/7/10 at 09:37 AM Reply With Quote
Thanks all... I knew you'd take care of me!
