Author: Subject: Repairing crack in GRP
L5W
posted on 16/7/10 at 11:12 PM Reply With Quote
I won't go into the details but basically thanks to this furry git......
....I now have this crack in the corner of my bonnet
Is there a relatively easy way to repair it? clear resin then polish maybe? or am I best to just leave it and live with it?
currently fighting the urge to cook a ginger cat curry.....
Thanks,
Lee
http://l5w-mk-indy-zetec.blogspot.com/
RazMan
posted on 16/7/10 at 11:26 PM Reply With Quote
Ideally you will need to drill a small hole in the end of each crack to stop them going any further, dig out every crack down to the matting and then carefully fill the lot with gel coat, failing that a respray.
Oh and if still fancy a cat curry, just have a word with your local Chinese takeaway
[Edited on 16-7-10 by RazMan]
Raz
MakeEverything
posted on 17/7/10 at 08:05 AM Reply With Quote
Mig weld the cat....
Earth on the tail and wire in the mouth!!
Kindest Regards,
Richard.
easisatman
posted on 17/7/10 at 08:47 AM Reply With Quote
you could prep the cat for a curry, it already has the ginger!!! just stuff with chili that should sort it. Call it moggy masala lol
sucksqueezebangblow
posted on 17/7/10 at 09:34 AM Reply With Quote
Also grind down the back of the crack and fill it with fibre glass repair paste. Then gell coat the front and finish with wet and dry.
cadebytiger
posted on 17/7/10 at 09:45 AM Reply With Quote
That's is really useful! I will have to do a similar thing soon.
Stott
posted on 17/7/10 at 09:48 AM Reply With Quote
What, weld a cat up?
[Edited on 17/7/10 by Stott]
Strontium Dog
posted on 17/7/10 at 09:52 AM Reply With Quote
They do this to damaged bike panels. You could solve two problems in one if you used the cat!
http://www.furrybikes.com/
[Edited on 17/7/10 by Strontium Dog]
Howlor
posted on 17/7/10 at 11:01 AM Reply With Quote
Have a chat with MK as they may be able to send you some matching gelcoat mate. At least you would get the repair as close as possible without the need for paint.
posted on 17/7/10 at 11:02 AM Reply With Quote
When I first read the title I thought it was going to be a post on 'Repairing GRP on Crack'!
It's Evolution Baby!
Mark Allanson
posted on 17/7/10 at 11:19 AM Reply With Quote
I have seen 'De Cat' pipes for sale, would one of these be of any use to you
L5W
posted on 17/7/10 at 11:55 AM Reply With Quote
some good suggestions thanks, will try MK first.
mog is still in one piece, for now....
cheers
Lee
