Author: Subject: Toying with a 27" mac computer or this milling machine
mangogrooveworkshop
posted on 20/7/10 at 08:29 PM Reply With Quote
Milling machine
[img]http://cgi.ebay.co.uk/ws/eBayISAPI.dll?VISuperSize&item=360216285155[/img]
[Edited on 20-7-10 by mangogrooveworkshop]
scudderfish
posted on 20/7/10 at 08:31 PM Reply With Quote
That and a smaller Mac
Mark Allanson
posted on 20/7/10 at 08:36 PM Reply With Quote
That and a lathe - if it rains a 27" Mac will be far too small, buy a parker!
daviep
posted on 20/7/10 at 08:40 PM Reply With Quote
Depends what you want to do with the mill? It's too small to do most automotive work on IMO.
Davie
mangogrooveworkshop
posted on 20/7/10 at 08:53 PM Reply With Quote
My Myford only has limited milling capacity so I was looking to use this for the slightly bigger bits that we mill out from time to time.
clairetoo
posted on 20/7/10 at 09:00 PM Reply With Quote
Much more useful machine would be one of these - to get an idea of how much more solid they are than that likkle machine , check out the weight - over a hundred K's more , but not that much bigger.................
Its cuz I is blond , innit
Claire xx
Will weld for food......
minitici
posted on 20/7/10 at 09:03 PM Reply With Quote
Go the whole hog and get one of these
Syil X6
mangogrooveworkshop
posted on 20/7/10 at 09:06 PM Reply With Quote
http://cgi.ebay.co.uk/MILLING-SLIDE-DOUBLE-SWIVEL-FITS-MYFORD-LATHE-/370338669314?cmd=ViewItem&pt=LH_DefaultDomain_3&hash=item5639e7a302
mangogrooveworkshop
posted on 20/7/10 at 09:11 PM Reply With Quote
I was watching that clark machine ....and the one we saw in machine mart looked ok even if we have to get some decent lead screws from http://www.marchantdice.com/ it would be better than the myford for making the bits and bobs for the cat and locost
clairetoo
posted on 20/7/10 at 09:39 PM Reply With Quote
They are a very good machine - I had one (not the Clarke one , but they come up with all sorts of names on......) and used to make all sorts of drag bike stuff on it .
Add a rotary table and a boring head and you can make just about anything on it - I did
Claire xx
Confused but excited.
posted on 20/7/10 at 09:47 PM Reply With Quote
If a 27" Mac is too small, what use is a pen?
[Edited on 20/7/10 by Confused but excited.]
dhutch
posted on 20/7/10 at 11:08 PM Reply With Quote
[ Confused but excited.]
Sigh!
907
posted on 21/7/10 at 05:58 AM Reply With Quote
Hi Mango'
My son Gaz has an Axminster.
It's big enough to mill a manifold flange so might be worth a look. Dirt cheap.
hth
Paul G
ruudbeckers
posted on 21/7/10 at 01:37 PM Reply With Quote
I think that clarke milling machine suggested by clairtoo is not much more than a fancy pillar drill. I wouldn't want a milling machine with a round column. Because of the horizontal forces during milling the milling head could rotate around the column. Furthermore you loose your X and Y coordinates when you move the milling head up and down. You are much better of with a vertical column whuch has dovetails. Just my 2 cents.
Neville Jones
posted on 21/7/10 at 08:37 PM Reply With Quote
OK, I'm going to use the word 'BEAVER', so lets get the schoolboy giggles out of the way first.
Look for a small Beaver mill, they come up on ebay often, and are in a number of the machine tool dealers secondhand.
They use proper tooling and do a solid professional job, that the cheapo Machine mart, Warco and similar type things will never do.
I've wasted the money and learnt. Now got a Bridgeport, but maybe a bit big for what you want. The little mill/drill is now used just for drilling, which it does well, but not brilliant due to the round post, with the problems mentioned above.
Nev.
