Killer
posted on 26/7/10 at 06:28 PM |
Zetec auto box
Does anyone know how to get the clutch cover off so I can to take off the flywheel, engines an X reg mondeo blacktop.
There doesn't appear to be any bolts anywhere near the cover or around the edge???
Will get a photo tomorrow if that will help.
Ta
Killer
MakeEverything
posted on 26/7/10 at 06:38 PM |
Ta
Killer
Clutch cover on an auto flywheel? hope not.
Youll need to unbolt the torque converter. Not sure how the zetec is, but i seem to remember some bolts in the centre?
Kindest Regards,
Richard.
Killer
posted on 26/7/10 at 06:43 PM |
Ahh is that whats its called cant see any bolts down the center but will have a better look tomorrow.
Keep the suggestions coming..
Ta
JAMSTER
i would think 4 bolts through starter motor hole in to converter
Killer
posted on 26/7/10 at 07:08 PM |
Just wondering if its just on splines and just needs a bit of encouragment to come off....
Is this a possibility?
Anyone got a haynes for a 2000 mondeo, the electronic version I have has got chapter 8 missing??? Guess which chapter I need
Ta
Killer
posted on 26/7/10 at 07:27 PM |
Looks like this bad boy
Ta
[Edited on 26/7/10 by Killer]
stevec
posted on 26/7/10 at 08:01 PM |
It will have a hole behind probably the starter hole as already said for access to the bolts that hold it on, find the hole and turn the engine untill
the bolts show up through the hole then undo them rotating as you go.
Killer
posted on 26/7/10 at 08:50 PM |
Ok, I'll have a shifty around there tomorrow, I remember feeling around there and there was a hole but the sandwich plate didn't have a
hole in it so didn't go all the way through.
Maybe looking at the wrong bit so will double check, thinking about only the threads are showing at the back of the flywheel so the head must be
inside the torque converter thingy.
Killer
posted on 27/7/10 at 06:26 PM |
Jamster & SteveC you are todays winners and have now been elevated to the position of sainthood
Thanks, of course you were right, I was feeling through the hole and thought it was the sandwichwich plate but it was a plastic bung, removed and nuts
right behind.
Cheers fellas
Rich
