Dopdog
posted on 26/7/10 at 08:18 PM |
I hate Cars!! HELP
Just converted my striker from 16v to 20v and I cannot get it to start
I have a spark and fuel, all it does is turn over but not even a splutter nothing it just turns over like no leads are connected and does not
catch.
any ideas?
posted on 26/7/10 at 08:19 PM |
Check all the basics, too much to think about there...
Killer
Incorrect timing??
r1_pete
posted on 26/7/10 at 08:21 PM |
Leads on the wrong plugs??
Mr G
posted on 26/7/10 at 08:28 PM |
As above might be the timing but you would expect to hear a bang or pop in the process. How strong is the spark when you check it? Can you smell fuel
after trying to turn it over?
austin man
posted on 26/7/10 at 09:08 PM |
is the ecu correct for the engine ?? you mention changing the engine but not ecu
Dopdog
posted on 26/7/10 at 10:08 PM |
The car is running an omex 600 ecu, I have just installed the raw map and it is the wasted spark version so I do have a good spark at the plugs? Also
I can look down the throttle body and see the fuel being injected in.
Paul TigerB6
posted on 26/7/10 at 10:19 PM |
Suggests you have no spark at all. Have you tried a plug out of the engine against the block to look for a spark yourself??
Dopdog
posted on 27/7/10 at 06:31 AM |
Yeah removed plugs 1 and 3 and can see the spark? its still dead
vinny1275
posted on 27/7/10 at 08:00 AM |
don't know the Omex stuff that well, does it tell you if you're getting any data from the crank position sensor?
Have you got a timing light to check that it is firing the right cylinder at the right time?
Try some ez-start down the inlet manifold - if it fires, then the map prob isn't supplying enough fuel - an engine will start when it's
rich but not when it's too lean - ez-start is a good way of checking for this....
HTH
Vince
bartonp
posted on 27/7/10 at 08:19 AM |
Check it's firing on no.1 plug with no.1 piston at/near TDC with all no.1 valves closed as a first approximation to timing - it should at least
fire if you have this & the other plug leads on right....
Dopdog
posted on 27/7/10 at 04:17 PM |
Thanks all, will try suggestions and get back to you
Dopdog
posted on 28/7/10 at 05:12 PM |
Hi Can anyone confirm the wire colours from the omex loom to the idle valve. I have the raw diagram but the omex manual uses another wire?
Dopdog
posted on 28/7/10 at 09:28 PM |
its alive had a crossed wire on the ignition module changed this then it kicked into life.
