Author: Subject: painting my uprights
mrwibble
posted on 29/7/10 at 05:24 PM Reply With Quote
Another day another question.
Here are my uprights before
after electrolysis + wire brush + power file.
any who after a bit more polishing, i'm going to paint them with rustoleum, i'm just wondering whether to paint the spinny bit with the bolts on (hub carrier?), obviously i dont want to create any friction between the spinny bit and the meaty bit, and/or affect the mating surface onto which the disc sits.
regards Ed.
graememk
posted on 29/7/10 at 05:49 PM Reply With Quote
have them chromed for extra bling
mcerd1
posted on 29/7/10 at 05:56 PM Reply With Quote
I powder coated mine but I stripped them down first and rebuilt with new bearings
omega0684
posted on 29/7/10 at 06:42 PM Reply With Quote
from experience get them done in Black! they won't stay silver for long i can tell you!
mrwibble
posted on 29/7/10 at 06:44 PM Reply With Quote
best not to give me too many ideas. but you've proved i can paint the hub. replacing the bearings sounds like a good idea... how do u get inside?
mcerd1
posted on 29/7/10 at 07:02 PM Reply With Quote
^^ nothing to difficult and its all in the haynes book:
dust cap comes off the back (try to save it - you might find it hard to get new ones)
then there is a big nylock nut
one side is left hand threaded, the other side right hand - make sure these go back on the correct sides of the car or they could undo themself as you drive
(you get new nuts with the new bearing kits)
there is a ridge in the midle of the upright so each outer bearing race comes out from its own side (you'll need a punch to persuade them)
best to press the new outer races into place if you can
you'll need a big torque wrench to tighten them (310-350Nm from memory)
and some high temp lithium grease to pack the bearing with
[Edited on 29/7/2010 by mcerd1]
omega 24 v6
posted on 29/7/10 at 08:44 PM Reply With Quote
The wheel mounting face should NOT be painted/coated at all.
RichardK
posted on 29/7/10 at 09:37 PM Reply With Quote
Maybe worth drilling them and tapping them for the second method of mushroom inset fixing before you paint them, again not good engineering practice to paint any faces, I would also repe the bearing whilst they are out and apart.
Just my 2 penneth well deposited.
Rich
Gallery updated 11/01/2011
RichardK
posted on 30/7/10 at 10:57 AM Reply With Quote
u2u replied but so others can see what I have described.
Hole drilled through side of upright and either into or all the way through mushroom.
Tapped out the upright
Job done!
mrwibble
posted on 30/7/10 at 12:46 PM Reply With Quote
i understand what your saying, but ford engineered these to be secured by a pinch bolt, does anyone have a story about that failing?
interestedparty
posted on 30/7/10 at 12:54 PM Reply With Quote
there's a tongue on the strut on the Sierra I suppose the idea is to stop the mushroom turning and comilg loose that way
James
posted on 30/7/10 at 01:42 PM Reply With Quote
Agreed. Unevenness in the paint threw my brake discs out enough that they caused a wobble and were rubbing on the brake pad and stopping the wheel turning properly.
James
James
posted on 30/7/10 at 01:45 PM Reply With Quote
I've not heard of anyone's failing.
But the point, is that a fair few people have failed IVA over this. So depending on your inspector, it's worth doing to save failing the test for!
James
mrwibble
posted on 31/7/10 at 08:35 AM Reply With Quote
ah i see. but for a fury i need not worry, bgh supply a machined ring, which the ball joint is threaded into, this cap has a tongue as used by ford. i did not see(read look) in RichardK's pics that he was missing this.
Lippoman
posted on 31/7/10 at 08:52 AM Reply With Quote
Ford engineered them for a strut, not a double A-arm. With a strut there is "always" force pushing the strut into the upright ...
Also the lower joint is in a completely different load case than in the original application. Usually you get away with it in a locost as less weight=less load.
mrwibble
posted on 31/7/10 at 09:28 AM Reply With Quote
i see. fortunately jeremy phillips seems to have thought of this already.
Lippoman
posted on 31/7/10 at 11:12 AM Reply With Quote
Sorry, didn't notice you seem to be building a Fury(?), the loads in that one are similar to original application.
I assumed your front to be similar as the one pictured earlier in thread, where the upright is "hanging" from the lower arm (spring/shock attached to lower arm). These need a lower joint designed for the application.
mrwibble
posted on 31/7/10 at 11:51 AM Reply With Quote
fury suspension. note the use of the pinch bolt through a machined ring, with a tongue, to cap where the strut would go.
