Kevin
posted on 1/8/10 at 03:56 PM |
Crossflow propshaft wanted
I want a propshaft to shorten or lengthen
for my locost. The Ford crossflow gearbox has 16 splines
and 30mm outside dia. The hole centers on the diff are 90mm. A lot to ask as I think it is a bit of a mix and match but its worth asking. I will get
one made if no success.
RAYLEE29
posted on 1/8/10 at 04:25 PM |
best bet to get one made quite a few companies out there and cost about £100
although i did do mine myself a few chaps on here have had nasty experiences with props failing and flailing
Ray
will121
posted on 1/8/10 at 07:19 PM |
is it for a 4 speed gear box? ive got one but its got a 70mm PDC axle flange 950mm long the uj's are cir clipped and grease nipples if that
makes it eisier to convert if you interested?
Kevin
posted on 2/8/10 at 07:32 PM |
Many thanks I think I will get a propshaft made just to be safe
