budha
posted on 2/8/10 at 10:52 AM |
The Odyssees goes on: Zetec Starter Motor
I have a 2l Zetec with a raceline flywheel mounted to a Type 9 Gearbox. But I cannot find a suitable starter motor. I tried the LRS707 first. No
Problems with the oil pan (also raceline), but the starter did not reach the flywheel. Then I tried the FRS543. This one reaches the flywheel but
collides with the sump. The starter seems a bit too wide.
The I need am smaller version of the FRS543. Does anyone know which partnumber is the one to go for?
snakebelly
posted on 2/8/10 at 10:55 AM |
surely raceline do on$e to go with their sump and flywheel? betting it wont be locost though!
posted on 2/8/10 at 11:19 AM |
1.8 zetec flywheel and LR707.
Cheap clutches form modern Mondeos!
deltron63
posted on 2/8/10 at 06:03 PM |
+1
budha
posted on 3/8/10 at 07:54 AM |
I already have the clutch and the flywheel. All I need the starter! But there seems to be a version of the FRS543 with a smaller register diameter.
This one should fit.
