the man with a plan
posted on 2/6/04 at 01:38 PM |
2.9 V6 Cosworth
Howdie,
Are all V6 2.9l ford engines classed as 'Cosworth'?
How easy would it to mount a Cosworth V6 and gearbox into a mcsorely +442? Will there be many issues with height and width?
If the block has come from a 4x4 sierra, will the sump have the front axel running through it, and if so what mods need to be done to make it run?
Finally, what would be a good price to pay for the lump and box together?
Thank you very much
posted on 2/6/04 at 01:41 PM |
Our 4x4 Sierra XR4i had a 2.9i engine (therefore not Cosworth). We got shut after taking off the bits we needed. We sold the remains including box and
engine for £150 IIRC.
the man with a plan
posted on 2/6/04 at 01:54 PM |
Now I understand, the 12v version came in 4x4s whilst the 24v, cossie, was available in granadas and scorpios. Do they share the same bottom end, with
the 24v having a special cossie head?
Any issues when it comes to mounting the box and engine? How wide is it?
Did the engine you sold have an axel running through the sump, or am i just imagining something that is very far from the truth?
Thanks again
posted on 2/6/04 at 02:00 PM |
IIRC (it was some time ago - Sept 2003) the front prop went down the n/s of the sump.
With reference to the other questions - there are far more knowledgable people on here to discuss those issues. Sorry I can't help you further
I've just discovered our 'donor section' didn't work I've uploaded it now so have a look in there they may be
something to help you!
[Edited on 2-6-04 by Hellfire]
timf
posted on 2/6/04 at 02:14 PM |
http://www.interford.co.uk/forums/
will give all the answers if you ask
also how to convert the cosworth to manual gearbox
stephen_gusterson
posted on 2/6/04 at 02:44 PM |
most granada will be the 12v non cosworth version.
atb
steve
mackie
posted on 2/6/04 at 03:05 PM |
The 4x4 version will indeed have the sump with the front driveshaft going through it.
4x4 Type-9/MT75 not worth modifying.
What you want is a 2.9 rwd manual granada - which are rare.
NS Dev
posted on 2/6/04 at 04:35 PM |
or get all the bits separately, then you can use a Capri 2.8i/Sierra XR4i/MK2or early MK3 granada manual type 9 "V6" 'box. You can
take the flexplate of an auto engine and fit the flywheel from a 2.8 to the 2.9 (which is much lighter too!) and there you have a manual transmission
on a Ford v6 from an auto car, but the Type 9 'box will go bang quite readily, but then you can get gearkits very easily (not cheap though)
compared to the kits for the MT75 which are remortgage territory!
nicklondon
posted on 2/6/04 at 04:39 PM |
there is an feature on the ford cologne v6 in the june edition of Practical Performance Car which explains all the differances between the models
posted on 2/6/04 at 04:50 PM |
MT75 boxes have been signalled the death nell (so prices should come down - in theory!). Production is being phased out to be replaced by the MT82/3
which is a 6speed box as projected to be fitted to the new Transit with paddle gearchange TRUE!
the man with a plan
posted on 2/6/04 at 09:13 PM |
Thank you very much for your replies, looks like I am going to have to reconsider my options.
Rob Allison
posted on 2/6/04 at 09:19 PM |
The new transit is front wheel drive. i think?
posted on 2/6/04 at 10:16 PM |
The new transit is deffo FWD.
Picture of 4x4 underbelly for your reference:
the man with a plan
posted on 2/6/04 at 11:34 PM |
Cheers for that, very handy!
CliveM
posted on 3/6/04 at 07:47 AM |
FWIW the cosworth block was stiffened, so a cologne V6 block is different.
How do I know?? Work for an engine remanufacturer and we found out the hard way!! Cosworth V6 blew up at 6000rpm while on a dyno!!! crank broke
into 3 pieces
hope this helps,
Clive
mackie
posted on 3/6/04 at 08:09 AM |
I think you can get the new transit in both front and rear wheel drive.
</ £0.02>
Noodle
posted on 3/6/04 at 08:25 AM |
</ £0.02>
That's what I understood too. My mate runs a business fixing Trannies (not blokes in frocks) and he says the newer ones are an utter pig to work
on. He also says the boys in the local Ford dealer hate the FWD one due to it's difficulty in gaining access and servicing costs have risen
accordingly.
The recent RWD versions have also become more difficult to work on. Older trannies need about 25 mins to remove the 'box, the newer RWD ones are
well in excess of an hour. That can work out pretty expensive with main dealer labour rates when you consider the reverse procedure is often desired
too
There again, he also knows a bloke who sells chip fat in vats for powering diesel vans.
Neil.
Your sort make me sick
stephen_gusterson
posted on 3/6/04 at 12:25 PM |
i read somewhere that the cossie v6 was actually made in wellingbough, northants
atb
steve
into 3 pieces
hope this helps,
Clive
nicklondon
posted on 3/6/04 at 01:34 PM |
transits avalible as fwd or rwd.and with manual or semi-auto gear boxes.buttons on steering wheel
DavidM
posted on 3/6/04 at 06:34 PM |
atb
steve
That's right Steve, Cosworth on Park Farm Industrial Estate.
Browser
posted on 3/6/04 at 07:33 PM |
I dunno mate, I think the one in the piccy is RWD. Look where the alternator drivebelt is and, more importantly, that it is oriented as if the crank
was running North-South. The runnign gear looks like i might be generic though i.e. bolt whatever engine and gearbox you want to it and it does the
job.
posted on 3/6/04 at 08:38 PM |
Browser...
You obviously haven't followed the full thread The first paragraph was reference to transit's. The second paragraph was with reference
to a Sierra 4x4
posted on 3/6/04 at 08:41 PM |
My brother's father in law has a Transit that isn't available in FWD or semi-auto, no buttons on steering wheel either Mind you it is a
1995 long bed!
CliveM
posted on 4/6/04 at 07:09 AM |
atb
steve
and re-manufactured here in Rushden!!
Clive
Browser
posted on 4/6/04 at 08:57 AM |
Browser...
to a Sierra 4x4
OK, I'll sit back down and be quiet then
(bugger!)
