Author: Subject: Wilwood Bias Valve – Dumb question
bilbo
posted on 14/8/10 at 09:49 PM Reply With Quote
I have a Wilwood Bias Valve like this one in-line to my rear brakes:
Wilwood bias valve
Wilwood bias valve
I'm just head scratching a bit as to which way is which. It says 'Decrease' on the handle with an arrow – does this mean decrease line pressure, i.e. reduce the rear braking , or does it mean decrease the restriction in the line, i.e. increase the rear braking?
Reading a few threads on here, I probably won't need it anyway, but seeming as it's already fitted, I want to set it to leave the pressure unaffected – I can always then change it if the rears lock up first.
Told you it was a dumb question
Oh, and before anyone asks, it's in the engine bay, so there is no way you can adjust it whilst driving.
Build Diary: http://bills-locost.blogspot.com/
Web Site: http://locost.atspace.com
prawnabie
posted on 14/8/10 at 09:53 PM Reply With Quote
I have used one like that and with the handle fully bent over the rear brakes were locked.
Wherever you put it it will fail assuming you haven't passed IVA yet.
bilbo
posted on 14/8/10 at 09:54 PM Reply With Quote
Why fail? I thought they would want me to get the brake balance correct?
Also, which way did you do it to get the wheels locked - that doesn't seem to happen to me?
[Edited on 14/8/10 by bilbo]
neo2
posted on 14/8/10 at 10:13 PM Reply With Quote
It should'nt lock the brakes totally which ever way you fit it its bias valve not a line lock..
Mines the screw type and decrease means decreases the pressure to the rear brakes ie less braking, and its also a willwood item..
Iva dont allow adjustable brake valves if i remember correctly, but as you cant reach yours from inside im not 100% sure if yours is ok or not...
Rob
bilbo
posted on 14/8/10 at 10:20 PM Reply With Quote
Rob
Thanks for that - That answers my question re which way it should go.
I wonder if the it will be OK for IVA if I somehow pin it in position, like you would do with a bias bar assembly?
Might just be easier for me to remove it - I'm just a little worried as I have a disk conversion on the back, but using a sierra M/C original for drums.
Rod Ends
posted on 14/8/10 at 10:52 PM Reply With Quote
www.wilwood.com/PDF/DataSheets/ds489.pdf
snapper
posted on 15/8/10 at 05:28 AM Reply With Quote
IVA requires the fronts to lock before the rears, if you don't know what happens without the bias lever, how can you set up the lever?
You could fit it and pin it but still need to address any problems at IVA.
Perhaps using locking wire would convince IVA man that it permanently fixed but you could at IVA cut the wire reposition lever and rewire if you failed on bias
[Edited on 15/8/10 by snapper]
I eat to survive
I drink to forget
bilbo
posted on 15/8/10 at 08:55 AM Reply With Quote
Thanks for the replies.
I simply don't have any way of testing what wheels will lock first, before I get it on the road - what have other people done to set up brake balance before the test? I was hoping to do as Snapper says and alter it at the test if it fails, but if this isn't an option I'm stuffed
interestedparty
posted on 15/8/10 at 09:28 AM Reply With Quote
You don't have any way of testing that after either Im afraid!
Thing is at IVA they test braking effort at several different pedal presuures, so even a MOT station cant test that, nor would driving it on a road, unless you had a road with lots of different surfaces.
If a car was being driven on a slippery road (maybe slightly oily wet road, for instance) and the rears were more efficient at LOW pedal pressure (which they might well be, even though less efficient at full pressure) then the car would spin if the driver braked gently in a curve.
The only answer is to try it on full pedal pressure (at MOT for instance, or on a private road, or even a gravel drive) and go woth your best guess, and go to the IVA. Your chance of passing first time is low anyway, so budget £90 for a retest .
bilbo
posted on 15/8/10 at 09:37 AM Reply With Quote
Thanks for that. I guess my best bet is to see if I can do it on the drive and take it from there. I'll also put one of those stickers near the valve as per bias bars, and hope they are happy.
I already suspected it wont pass first time, but the more I get right before I go, the better.
Thanks again,
Bill
RazMan
posted on 15/8/10 at 10:07 AM Reply With Quote
Another factor to consider is bedding in the pads & discs makes a LOT of difference to braking performance and balance. When my car was tested (SVA) everything was brand spanking new and the tester allowed me to do a few laps of their 'circuit' to try and get a bit of heat into the brakes. Needless to say it was a bit of a gamble and I was gobsmacked to pass - the car had never been run before the test! The force needed on the brake pedal was actually painful
Later, with a few miles on the clock, the braking performance was vastly different from the test. I needed to reset the bias bar to stop the fronts locking up. Sometimes the test parameters don't make any sense .....
Raz
bilbo
posted on 15/8/10 at 10:16 AM Reply With Quote
Good point on the bedding in. I'd planned to drive the car to IVA to bed everything in, but then that messes up any tests I do on my drive.
I have to say, I'm bricking it a little re IVA before I've even got a date.
After 4 years of build, I'm finally almost there and I'm getting paranoid about everything.
Doesn't help as well that I started building to SVA regs, then had to rethink stuff when IVA came in
[Edited on 15/8/10 by bilbo]
ReMan
posted on 15/8/10 at 10:31 AM Reply With Quote
Bear in mind therre are pleenty of our cars out there without adjustable bias pedals and without an in line device like this that are working perfectly well.
I'd say if in doubt leave it out
matt_claydon
posted on 15/8/10 at 05:48 PM Reply With Quote
Bias valves are not allowed for IVA, doesn't matter if it's locked.
Note 4: Hydraulic valves that only operate automatically and react to vehicle loading or braking forces are permitted (Load Sensing and Gravity valves) Manually adjusted valves (other than to permit presetting the automatic function of a valve) are not permitted to be fitted even if they are rendered un-adjustable.
bilbo
posted on 15/8/10 at 09:40 PM Reply With Quote
Well, that's clear then. I'll have to remove it. I'll just have to hope it will be OK?
Personally, I think this is a stupid rule - to me, a manually operated valve is the perfect solution to get the bias set correctly.
So why, then are bias bars still OK?
procomp
posted on 17/8/10 at 10:20 PM Reply With Quote
Hi
If you get completely stuck with whats happening at the calipers with differing pedal pressures and fancy a trip to Brum. I can run our brake bias gauges on the car. It measures line pressure at the calipers giving percentage or actual line pressure readings.
Cheers Matt
